My 2005 videos
Originally Posted by 89sleeper
http://www.putfile.com/89sleeper
I hope to add more next year
Very nice videos 89sleeper! Can you list your mods? Also are you still using the TPI intake? Or you running an aftermarket one? Do you have any more vids? Sweet 89
Location: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
1 Post
A GM parts direct 383 stroker short block externally balanced with aluminum 20lb Fidanza flywheel
TPIS 409 roller cam and hardened push rods and roller timing chain and gears
Edlebrock performer heads 60cc and roller rockers arms
TPIS miniram and 52mm throttle body
30lb Accel injectors
TPIS ceramic coated headers and low restriction mufflers
Taylor plug wires and K+N air filter
TPIS prom chip
The car has factory gears 3:54 rear axle and factory 6speed
This is what my coupe has for mods
TPIS prom chip
TPIS prom chip
Nice setup. They came with 3.54s from the factory? Also some ppl told me that the ZF isnt all good. I guess they were wrong. It can handle good power!
