Folks:
I am not making this up. I have a 93 automatic C4 and when I am on a patch of ice with the brakes pressed to the floor, I have a phenomenon going on between the power applied to the wheels and my braking system. The engine is applying power to the wheels at the same time the brake system is trying to counter act the slippage on ice. The net result is that the car creeps forward at a slow rate of one mph. This can be very disconcerting when you are approaching an intersection and you cannot stop. The rear wheels alternately drive the car forward with the front wheels locked up. The only solution is to put the tranny in neutral. Has anyone else experienced this phenomenon?
Not quite from a stand still, but every RWD vehicle I've ever owned stopped much faster in Neutral, than Drive on snow and ice.
Stock rear brakes on cars are typically weaker to reduce oversteer because oversteer is considered "unsafe" in a court of law compared to understeer.
If you are truly at a stop, and you put it in gear, it probably should not creep forward, could be a brake problem.
There are three important things a car needs to drive on snow & ice well. tires, tires, & tires. If you have Z-tires on, which often are not heavily siped, if at all, the only tire that is worse on ice is a mud terrain. ABS is nice, but it can't create traction.
YMMV »keith
The rear tires are brand new Z rated. I believe that is some kind of limited slip mechanism that doesn't allow the accelerator to cause the tires to spin. This may be causing the brakes to partially release or something because I hear and feel the brake pedal vibrating, etc.
That's your ABS. It's possible they are letting off the brake pressure to get the wheels to roll, and that the engine is then causing this to creep. Ice is like practically no traction at all. You might try putting the tranny in N and seeing if that helps.
Mine does the same thing - I drove my car last winter for the first time ever in snow and ice. I have lived in South Carolina for the past 14 years and although I grew up here in Maryland I had never driven my Vette in any snow. I got caught at work and had no choice but to get it home. I put it in neutral at lights (if I could stop), and whipped the Azz end around by turnin'n the wheel and stabbin' the throttle to point the front end in the correct attitude for straight ahead driving. It was weird that when I was sitting still with my foot on the brakes, the rear wheels are still spinning. I know that people sitting next to me were thinking I was crazy!!
With an automatic, the car is always pushing a bit especially if your idle is a little on the high side..on dry pavement this is not a problem, on ice it is a major problem..put it in neutral before you get to the stop..it should stop fine as long as you aren't going way to fast for the conditions. I own a 1971 Mach One with an auto in it..no way will that car stop on ice with the tranny in gear..and even if it does manage to stop the real wheels will spin and cause the rearend to do a little dance..put it in neutral..and you should be fine
I have never had this problem in our Vette, but my Dad had an old Monte Carlo, and shifting into neutral was a requirement when stopping in icy conditions. Its a shame when our cars have that much power
Its just the nature of most of the auto's, they creep at idle power. Thats why you have to keep your foot on the brakes on dry pavement or you will kiss the car in front of you. Just pop it into neutral, its uses about as may brain cells as putting in the clutch on a stick.
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Originally Posted by DDSLT5
You should be able to lock the rear wheels with your foot to the floor.
Absolutely.
With the engine at idle, the brakes should easily lock the rear wheels.
Sounds to me like some weird ABS interaction is releasing the front brakes.
Thank you all for the advice. I do put it in neutral but didn't realize that this was a "feature" on Corvettes. It was a little disconcerting the first time, but after that I had no problem. I thought I was the only one in town with the problem. I believe the real solution is to trade it in for a new C6 with a stick. What do ya think?
Get a 4x4 gas hog for the ice storms. C6 good ldea but not for ice.
Get the C6 I bet they are even better in the snow than a C4!
