engine internals....threadlock
Old Dec 12, 2005 | 10:36 PM
sonomacrew01's Avatar
sonomacrew01
Default engine internals....threadlock
Is threadlock a good idea when bolting things back up whether or not its internal (moving parts) or outside the engine. Or are the torque specs adequate enough.I just can't justify 21 ft. lbs. is enough to hold down the camshaft sprocket...
Old Dec 12, 2005 | 10:52 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I use it on things like that too, in many cases. Especially, if like you say, the torque spec seems barely adequate.
Old Dec 12, 2005 | 10:58 PM
Pete K's Avatar
Pete K
Torque is a conversion of stretch. If torqued properly, in theory, it cannot loosen. I admit, cam sprocket, lifter spider and cam retaining plate are locktited on my stuff.
Old Dec 13, 2005 | 12:03 AM
VinceC4's Avatar
VinceC4
Default sure use it
the force on a cam sprocket is a sideways motion very unlikely it will come loose but you can use loc-tite..can't hurt
To engine internals....threadlock
