I know you want a wood burning stove but for a $100 I use my propane heater on a 20# tank and with the 0 degree temps as of recent I've been plenty warm in a t-shirt and overalls to do my work. 45000BTU and its plenty warm for a 1200 sqft garage. I put it on a rolling cart that I bought at Menards with both the stove and tank and a large extension cord and move it to wherever I may be. I never have to open the garage and can be out there for years. I agree with the others about the kerosene heaters. I don't like the fumes.
Here, Kerosene is $6.00 a gallon. Propane is $2.13 a gallon.
Natural gas is going up 41% and it will go up forever.
Wood here is $375.00 to $400.00 a cord. I found a pellet stove to be the cheapest way to heat my place.
You can add a sub panel for your garage and then you can use whatever kinda heat you want. Plus more power in the garage is good if you want to add a welder or bead blaster.
I have one of those propane feuled shotgun heaters that sounds like a jet engine when running. Does a great job heating the garage but it is so noisy you can't listen to the radio or even think. I also have to keep the garage door open a couple of feet for safety too.
The idea of using the Menard's heater sounds great!
I have use one of these (kerosene heaters) for years. I have found that the fuel makes a big difference. I get a very clean fuel from Home Depot that doesn't smell as bad as some. It is quite expensive though.($5.00 per gal approx.) That is the only draw back. I have also used bulk kerosene that really stunk up the garage. I don't leave the garage door open at all but I probably should. So far I haven't experienced any dizzyness or anything.
Dayum ....375-400 for a cord. That is insane and I consider it fleecing.
Burning that kind of money is not cost effective. Ouch!
I don't know if it was already mentioned or not, but Reddy Heat makes a vent free heater that you can buy selecting either propane or natural gas. They come in different sizes and can probably handle what you are looking for.
I am considering doing the same thing, I just am not sure how much work I will be doing in the added garage.
I use a wood burning stove because it is cheap...I just burn the sticks that fall off of my tree and any free wood that I get.
I also have a kerosene heater, the type that doesn't stink because it gets rid of the fumes somehow.
The best thing that I did was insulating the garage. It is important to insulat so that the heat isn't simply going out the walls.
I think you really do need to vent a door with those things. Red blood cells have a greater affinity for CO2 than oxygen. I've read that you don't know what hit you, you just pass out.
Some immigrants here were having a party of sorts in the garage a few years ago and someone decided to start the car becuse they had the stereo running. Call it Darwinism, but they all died.
I'd think the kerosene heater generates a lot less CO2, but still, wouldn't want to take a chance with it when the stakes are that high.
I have a 45,00 BTU natural gas Infrared heater by Superior Radiant Products in my 3 car garage. What I like about it is that it actually heats the objects in the garage not the air, nice to have warm tools. When I open the door the recovery time is very quick. It is direct vent and fairly quiet.
I put a 100,000 BTU house furnace in my 3 car garage . I have 6 vents in the ceiling, I used flexible insulated ductwork to keep it simple.
And I boxed out my rafters and made a square for the return.
Works great. I keep it at 42 degrees,,,,,,,,,warms to 70 in a few minuts when I want to work out there.
I even put a A coil in in the event I come across a compressor,it will have A/C to !!!!!!!!
Did the same exact thing, only with an 80K BTU and a 2.5 car garage.
I keep it at 45 and it will also get to 70 quickly and is very comfortable heat. Mine is propane, tank is behind the garage. I put my return as high as I could on the lift side (about 13' ceiling). Mounted the unit in the attic, nice and quiet. Total DYI cost about $1000 but well worth it.
