Bedtime--Float Charger Info...
Old Dec 15, 2005 | 07:19 PM
trvette's Avatar
trvette
Default Bedtime--Float Charger Info...
Hi all,
Well the salts been laid down on the roads here in Maryland and now
it's downtime time for the vette ('92 LT-1). Got a float charger and wonder if I can just hook it up to the battery (without disconnecting the battery cables and removing the battery)...to let 'er stay charged up for the winter?
Thanks in advance....
......just a waitin' for spring...
Old Dec 15, 2005 | 08:37 PM
mfi's Avatar
mfi
I just hooked mine up with the spring clips. I didn't feel like disconnecting the cables.
Old Dec 15, 2005 | 08:50 PM
VinceC4's Avatar
VinceC4
Default I just hooked mine up
I use a trickle charger that will handle up to 4 batteries..I hook up my Vette as well as my '71 Mach One (Ford)..I leave the terminals connected on the batteries..have been doing it now for a few years never had a problem
Old Dec 15, 2005 | 10:30 PM
jlbruggeman's Avatar
jlbruggeman
No need to disconnect-Right now I have one on each Vette, one on a motorcycle, and one on a garden tractor.
Old Dec 15, 2005 | 10:34 PM
jfb's Avatar
jfb
It is safe to leave your battery connected while charging it!
Old Dec 16, 2005 | 12:11 AM
SJW's Avatar
SJW
Leave the battery connected. If you disconnect it, you'll lose your clock and radio settings, and your alarm system will be inactive. There's no good reason to disconnect it, and a few good reasons to keep it hooked up.
Be well,
SJW
Old Dec 16, 2005 | 07:56 PM
trvette's Avatar
trvette
Be well,
SJW
Sounds like solid advice....Thanks to all for the replies...
Happy Holidays!
Old Dec 16, 2005 | 11:51 PM
deerra's Avatar
deerra
I got a cigarette lighter insert from Radio Shack and just plug it in. Works great.
To Bedtime--Float Charger Info...
