hi coolant temp help
Old Dec 17, 2005 | 01:54 PM
JAYK's Avatar
JAYK
Default hi coolant temp help
Looks like electric water pump failed and coolanmt hit 279 ,what damage has this likely to have caused
Old Dec 17, 2005 | 02:02 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
If you caught it in time, nothing...
If you ran it like this for a long time, warped heads, blown head gaskets and other nice things may have occured
Old Dec 17, 2005 | 03:07 PM
hippy's Avatar
hippy
How long did it run at that temp? May want to change the oil. Just a thought.
Old Dec 17, 2005 | 05:01 PM
JAYK's Avatar
JAYK
drove car for maybe one mile or less like this,when I stopped and lifted hood steam was coming from overflow tank in the front end
Old Dec 17, 2005 | 05:04 PM
*89x2*'s Avatar
*89x2*
Take care of your water pump issue and then fire the car back up - see how it reacts then. You will know real quick if a head is warped / gasket blown
My TA - an L98 went that high, or higher on the 14th st bridge in Wash. DC 4th of July a few years ago - no issues other than the split sidetanks on the radiator
Old Dec 18, 2005 | 12:41 PM
rick lambert's Avatar
rick lambert
Check your oil before and after you fire it up.
Old Dec 18, 2005 | 08:46 PM
czissman's Avatar
czissman
I would definately change the oil. From what I've read, getting oil above about 250 has an immediate deteriorating effect on it.
Old Dec 19, 2005 | 08:15 AM
runner140*'s Avatar
runner140*
Mine got up there but not as high when I was stuck at an intersection/redlight for 22 minutes. The car overheated, pulled off quickly and let the engine cool off. Changed the oil and coolant the following day. No damage.
Old Dec 19, 2005 | 09:16 AM
MR NICE's Avatar
MR NICE
I would do a cylinder leak down test before starting or putting water back in it.
Old Dec 20, 2005 | 01:50 PM
1995babyC4's Avatar
1995babyC4
Default Coolant Temperature shoots very high
It happens to my C4 periodically still, after i checked almost everything and brought my C4 to a dealer. Now, what i learn is 2 things: First, you need to turn on the AC fan. It really helps to lower the temperature, someone on this forum mentioned to me that C4 has a chip that sets at certain level so at certain speed the fan doesnt turn on (my experience tells me if i drive below 30mph, i do need to turn on the AC fan). Second, check the coolant fluid.
Hope it help
1995babyC4
To hi coolant temp help
