rear diff seal
Old Dec 24, 2005 | 10:12 AM
sonomacrew01's Avatar
sonomacrew01
Default rear diff seal
I dismounted the rear differential and opened it up to inspect the gear teeth. All is fine and i'm going to keep the stock setup but I noticed there is no gasket. What kind of mating sealer do I use to plug them back together?
thanks
Old Dec 24, 2005 | 10:21 AM
Pete K's Avatar
Pete K
You will get many opinions on this. My silicone of choice is Permatex Ultra Copper. It is the only sealer that has not let me down yet. The real key is the prep. Scrape it spotlessly clean, make sure it is abolutely clean. I use laquer thinner for this step. Then apply rtv, give it a few minutes to flash, but not skin over. Install batwing and torque to spec. I always let it sit for 24 hrs to let it cure. Longer if in cold weather. Then I fill the fluid.
Old Dec 24, 2005 | 11:04 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Permatex's "The Right Stuff." A Permatex rep told me it is better than their best silicone products with several times the service life, as well as better sealing. Their two best silicones, in descending order, are Ultra Gray and Ultra Black. Ultra Gray contains ceramic particles to make the cured product extra durable.
aboatguy's Avatar
aboatguy
I used the "right stuff" and have no leaks. It is a little pricy but it seals quickly.
Mike
Old Dec 24, 2005 | 11:10 AM
Corvette Kid
I almost forgot. He also told me that gear oil attacks sealers more than any other automotive petro product. The Right Stuff is more resistant to that, too. Whatever you use, let it set up before refilling with lube. 24 hours, or at least overnight with silicones. The Right Stuff can be put into service much more quickly.
Old Dec 24, 2005 | 11:46 AM
sonomacrew01
Nice. I have a can of that stuff... I used it on my timing cover... I am having the rear diff sandblasted....
Old Dec 24, 2005 | 12:02 PM
Corvette Kid
I hand sanded mine (I'm a masochist ) and then used Scotchbrite to get a smooth finish on it. Much easier to keep clean now!
To rear diff seal
