700r4?
Old Dec 27, 2005 | 12:14 PM
blown87's Avatar
blown87
GA Events Coordinator
Default 700r4?
I have a 87 auto. The question is should i be able to pull the the gear selector into first gear and have the transmission go into first?
i have heard that mine is working like it should, but once it goes into second pulling the gearshift into first does nothing.
is there a adjustment or another fix? transmision shifts fine, fluid gets flushed often.
thanks
Greg Nettles
Old Dec 27, 2005 | 03:03 PM
ZumZum's Avatar
ZumZum
I had a problem similar to what you are describing. The leather boot around the bottom of the shifter was getting in the way. Before I attempt to put my shifter in low gear, I tug and pull up on the leather behind the shifter. After that I am able to pull the lever all the way back to 1st.
Good Luck!
Old Dec 27, 2005 | 03:44 PM
Pete K's Avatar
Pete K
It is likely a linkage adjustment problem.
Old Dec 27, 2005 | 03:58 PM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
If you pull the shifter down into first, the transmission should shift into first.
Old Dec 27, 2005 | 04:26 PM
ZumZum's Avatar
ZumZum
I thought the same thing about mine. But I found out it was the shift boot getting in the way. That is a simple and easy thing to check. If that doesn't work. Then it is more then likely a linkage adjustment.
Old Dec 27, 2005 | 05:47 PM
blown87's Avatar
blown87
just the man i had wanted to answer my question
i will try to adjust it tomorrow if we have a rack free.
thanks guys
To 700r4?
