car ramps
Hope this helps.
The basic plan is to stack four 2 X 12's of diminishing length (78", 60", 42", and 24") on top of each other (screw/nail them together as you stack them and put a stop block at the end of the top one. This creates a stepped ramp that is pretty heavy, so it will not push away when you roll up on them. For extra safety, you could probably screw a 2 X 3 along each side of the ramps to guide you onto the ramps and keep you from driving off the side.
The finished ramps will have a 24" long top platform and three 18" long steps leading up to the top. Since "2 by" lumber is actually only 1 1/2" this will give you a 6" high lift. If you want to go higher I guess you could add another level. You could also bevel the leading edge of each step to make driving up onto them a little smoother.
Anybody out there ever try DIY ramps......beats paying $1,300 for a Kwiklft.
Lift is 10 inches and 14 inches wide to accomadate my wide 10 1/2 inch tires. After years of using a jack with jack stands, these ramps are the way to go.
Use them on all my cars, so much easier to drive up the ramps and with these ramps low clearance cars with spoilers, etc can clear the ramps.
They weight 15 lbs each, easily handle, each ramp good for 1200 lbs.
You should see what kind of ground clearance you get when using them on a SUV!
They are expensive at $269 for a set plus $30 freight. But I couldn't see building a set of wooden ramps with their weight, etc. But I use them for all my cars. What a time saver!
I've used them to change the auto pan oil/gasket on my 96 Vet, flush out the cooling system by removing the knock sensors from underneath, lifiting the rear end to suck out the rear axle fluid, etc, etc.
They don't slip when driving onto them, just slowly creep up them. They will last a lifetime.
Besides my Sears jack couldn't get under the Vet because of clearnance.
As to ramps such as rhino, from what I've seen/read, they're quite safe although the stronger ones are sometimes recommended. I think there's one set that holds up to 2K pounds each. I know it's just me, but I've always had a problem hitting the ramps just right, and it takes me several tries. And I'm always worried about going off the end of them!
From corvetteronw's excellent (and obviously on everyone's mind) long thread on being careful re getting under your car, I picked up at least a few things: the first being, safety, the second being safety and the third being safety. Just from reading the posts by several (many?) others about their "incidents" such as collapsing jack stands, collapsing jacks, etc., it became obvious to me that some of the things I've done in the past are just plain russian roulette.
What I also saw from the thread was that ramps can be great things. To me only, some of the best were the homemade jobs which were fairly elaborate. And safe.
Granted, the two and four post lifts are expensive, but one small mistake under your car and the real question becomes: just exactly how much is a life worth?
The rear tires are on top of the ropes when the front tires are travelling up the ramps.
No slippage.
No slippage.
honestly i would never have thought of that
No slippage.
1) Place your ramps where you want them to be in either the garage or out on the driveway.
2) Just past the back of each ramp drill 2 holes 5/8" wide & 2" deep and spaced 6" apart.
3) buy some 1/2" round barstock and cut yourself 4 dowels 2.5" long
4) incert your 4 dowels into the holes and place the back of each ramp against its 2 dowels (now sticking up 1/2") your ramps will butt up against the dowels and not slide.
When you are finished just pull out the 4 dowels and store them with your ramps for the next time.
Thats what I use.
