Bumper Paint?
Old Dec 28, 2005 | 11:51 AM
Yakko's Avatar
Yakko
Default Bumper Paint?
I'm getting my battery and alarm sitch sorted out, just not enough hours in the day.
On to my next question, the bumpers are faded, the front pretty much completely and the rear just on the top.
There is a special blend for the bumper paint, correct? Should I go to a Chevy dealer or elsewhere to buy the paint?
Planning on touching it up myself.
Thanks.
'86, Metallic gray.
Old Dec 28, 2005 | 09:33 PM
Insane1's Avatar
Insane1
Don't know about yours but I repainted my black bumbers with bumper paint I bought at an automotive paint store. I wet sanded the bumper to get the clear coat off and sprayed it. Let it sit about 20 minutes and then sprayed 3 coats of UV clearcoat I bought at the same paint store.
Old Dec 28, 2005 | 09:38 PM
okies93's Avatar
okies93
St. Jude Donor 06
Go to a paint supply store. They probably supply the dealer with their stuff anyways. There are several good name products, PPG, DuPont just to name a few. Plus there are some paint shops that can take your paint code, mix the paint and put it in a spray can, pre-mixed.
Old Dec 28, 2005 | 11:12 PM
Yakko's Avatar
Yakko
Thanks, all good info. Probably won't get to this project for a few weeks, but I can look into the right paint store in the meantime
Old Dec 29, 2005 | 12:14 AM
goldeneye_vet's Avatar
goldeneye_vet
I would take the car with you and see if they have something called a colorometer. This is a device that is the size of a small shoe box and is placed on your car and is pushed down like a stapler to get the exact color match properties of your paint that is good so that you can match the bumper paint and not have two or three different colors. If they have one of these in my small midwest town I have to guess they'll have it pretty much anywhere.
Old Dec 29, 2005 | 01:06 AM
Yakko's Avatar
Yakko
I'll check into that. Is yours a major retailer or a mom and pop?
Old Dec 29, 2005 | 04:52 PM
Deakins's Avatar
Deakins
With Urethane paints what gets put on the body gets put onto the bumpers. Just get the proper color mixed in high end Dupont or PPG and you will be fine. It will flex, bend, and not fall off. Good luck.
Old Dec 29, 2005 | 05:15 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Make sure you get the paint that will flex or get the flex additive.
Old Dec 29, 2005 | 08:48 PM
Yakko's Avatar
Yakko
Thanks!
To Bumper Paint?
