lug nut torque ?
Old Dec 28, 2005 | 04:41 PM
ZRWON's Avatar
ZRWON
Default lug nut torque ?
I took the stock chromed wheels off my ZR1 to clean the wheel wells. Now that it's done and time to remount the wheels I can't remember the torque that should be used to tighten the lug nuts. Will one of you help this senile old guy out...PLEASE? TIA
Old Dec 28, 2005 | 04:46 PM
Bigredwing's Avatar
Bigredwing
100 ft lbs on my LT1 with factory wheels. Should be close to that.
Old Dec 28, 2005 | 04:51 PM
MNorlander's Avatar
MNorlander
I don't know much but I remember reading on the spare tire instructions to go 80ft lbs. You can check yourself it's on the lids of one of the storage bins.
Old Dec 28, 2005 | 05:05 PM
aboatguy's Avatar
aboatguy
You are both correct IAW Helms manual :
140 N m or 100 lb ft standard wheel
110 N m or 80 lb ft compact spare
However, I don't think he cares about the compact spare.
Old Dec 28, 2005 | 05:08 PM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
I usually go to 75 or 80 lb ft.
Going to 100 makes them a beyotch to get off sometimes.
Old Dec 28, 2005 | 05:12 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Old Dec 28, 2005 | 09:02 PM
aboatguy's Avatar
aboatguy
I have found 100 lb ft pretty easy to remove with even an 6 1/2" long 3/8" drive ratchet, with a tire iron it becomes a one or two finger job. I just hope that your lug nuts don't find their own way off since they are 20-25% under torqued. Don't they have a weight room at your college?
Last edited by aboatguy; Dec 28, 2005 at 09:07 PM. Reason: oops 3/8" ratchet is only 6 1/2" long
Old Dec 28, 2005 | 10:43 PM
Daddy J's Avatar
Daddy J
Hi- On the subject of lug nut torque. While I know one isn't supposed to use grease on the studs does that also apply to anti-sieze?
Old Dec 29, 2005 | 12:33 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
HUH?!?
Old Dec 29, 2005 | 02:23 AM
VetBoy89II's Avatar
VetBoy89II
100# is manufacturers recommendation. Although it is true that it can be a biotch to remove by hand if you get a flat, IMHO I'd rather have it harder to get off than easier to come off by itself
And yes, 80# is the man. reco. for the spare, but then again a spare is a tire that's only reco. to drive around 55mph.
Old Dec 29, 2005 | 02:25 AM
VetBoy89II's Avatar
VetBoy89II
There are NO stupid questions ... NEVER put ANYTHING on your lugnuts, except 100#'s of torque.
Old Dec 29, 2005 | 08:11 AM
aboatguy's Avatar
aboatguy
Old Dec 29, 2005 | 09:40 AM
TR Vert's Avatar
TR Vert
If you use use grease or antiseize you would have to increase the torque beyond the 100 ft-lbs.
The 100 ft-lbs is for dry threads. It gives the correct friction to prevent the dry lug nuts from backing off
Old Dec 29, 2005 | 11:44 AM
Nathan Plemons's Avatar
Nathan Plemons
I use 100 ft. lbs when I'm at the garage and I have the wrench handy. Otherwise you can get a feel for "tight enough" if you do it enough time. Sure the torque wrench is always better, but a calibrated elbow doesn't hurt.
You can do like my friend does and torque them to "two inch pounds," when the vehicle rolls two inches, you're done.
Old Dec 29, 2005 | 01:10 PM
allaboutcars's Avatar
allaboutcars
hi i have a calibrated elbow but it usually involves 12oz cans
To lug nut torque ?
