1984 problem child
I recently bought a 84 corvette from my brother in law.He(in all of his wisdom) had connected a set of jumper cables crossed. It took out a link off the starter. With that repaired, it won't start. I have power to the HEI but no spark. ECM shows normal codes when accessed. Also, the fuel pump does not run. The local guru of vettes suggested that I check the C341 fuse link located in the rt. side of the engine compartment. Any ideas where it is located there?
