Diff Bushings
Old Jan 14, 2006 | 03:12 PM
Leon10003's Avatar
Leon10003
Default Diff Bushings
Hello All!
Good news, thanks to some forum members, I was able to remove the diff. and carrier form my car.
The next question is :
How do i remove the bushings from the carrier so i can replace them with some polly ones?
Cheers
Old Jan 14, 2006 | 03:25 PM
aboatguy's Avatar
aboatguy
I used a press to remove the rubber part of the bushing and a hammer/ chisel and press to remove the metal sleeve.
Old Jan 14, 2006 | 03:59 PM
Leon10003's Avatar
Leon10003
What kind or press?
I have a hand press....but I dont think it is strong enough to do the job.
Can I drill out the rubber around the metal piece?
Old Jan 14, 2006 | 05:17 PM
goldeneye_vet's Avatar
goldeneye_vet
Drill the rubber out and then use a hacksaw blade to cut the inner sleave. Both are a pain but since you have the carrier out of the car be careful not to cut the carrier itself with that hacksaw blade.
Old Jan 14, 2006 | 05:53 PM
aboatguy's Avatar
aboatguy
Originally Posted by Leon10003
What kind or press?
I have a small 20 ton hydraulic press.
Nathan Plemons's Avatar
Nathan Plemons
A hydraulic press is the way to go. I didn't remove mine from the car so it was a real pain to get the carrier busings out. If the carrier is already out it shouldn't be very hard to find somebody to help you press out the bushings.
To Diff Bushings
