Replacing Timing Gears
Old Jan 16, 2006 | 03:50 PM
GIMMESOME's Avatar
GIMMESOME
Default Replacing Timing Gears
Hello and thanks to everyone.I took your advise and since i had to change the water pump i changed the chain 98,000 it was getting
pretty loose,also had to change the harmonic balancer,it had slipped
back almost touching the timing cover,what do you suppose could have
caused that?Well,eveyone was right,getting that balancer off was a
real pita!!!
I opted not to change the pan gasket and front pan gasket seal yet,i don't have ramps built ,but i will soon.I just took a razor blade,cut the
front pan seal on each side,cleaned everything real good slatherd the pan,timing cover,and the seal i cut free with rtv crammed her in and
bolted her down.It's only temporary,and it dosn't seem to be leaking.
It's amazing how much better an engine performs with a new gear set.
Anyone have any ideas how to build a portable ramp system of some
kind that is light enough to carry,but safe enough to hold the car?
thanks again.
Old Jan 17, 2006 | 02:39 AM
yellowlust's Avatar
yellowlust
It's recommended to keep the title of your thread relevant to the subject of you post.
So, are you replacing your timing gears (which should be replaced with the chain) or do you need ramps?
Old Jan 17, 2006 | 02:45 PM
ejscarfo's Avatar
ejscarfo
You could have replaced the stock timing cover with a 2 piece one. You don't have to drop the pan to install it. You just install the bottom piece first and then the top. It comes in handy when you advance or retard timing directly at the cam gear. I have installed it in a couple of Chevy's and found it was worth the extra $$$$ for the ease of installation.
If you chose to re-install the stock cover, all you need to do it loosen the front bolts of the pan so it has some play. The way you can catch the pins on the block to mount the cover and you dont need that much RTV, makes for a cleaner job.
To Replacing Timing Gears
