Check your fix from Breathless!
I installed the ring or collar fix that Breathless sent me back in early July. So the other day while washing the car I decided to look at it closely. The ring or collar that they sent has buckled already. It just can't handle the heat generated in that engine compartment. Anybody else have the same problem??
Re: Check your fix from Breathless! (corvettemaster)
Hey CowboyNVette, I'm over here in Mandeville. And yes it appears the Breathless fix needs fixing. They do seem to focus more on the C5 cars. My brother doesn't have this problem with his C5 Vortex system. Much sturdier construction on the C5. I wonder if Breathless will give me my money back? I am not happy and plan to switch to another cold air system.......
Re: Check your fix from Breathless! (Gate2)
I say we all get together and demand our money back! I ordered the fix kit.. but if this is what happens to them, I'm not going to bother with them! I didn't buy a vette to strap and tape of things!!!!! That's probably why my car didn't win best club car at the show the other day.. everyone saw the Vortec and it's condition and said, "I'll pass."
Re: Check your fix from Breathless! (kbuicker)
I don't blame you Kbuicker and Gate2, you should be able to get your money back if this fix is just as bad :mad . You know from the service that I have seen on this forum that Breathless has given to C4s I don't think I will ever do business with them. If they think that is ok well so be it. They may be just concerned about the C5 market but I hope they are educated enough to figure out that we will either be C5 or C6 owners one day. Some of us much sooner that others. :yesnod:
IMHO, Breathless= :bs
I just checked my "fix" and it is still intact. This does not mean I'm satisfied with it, but it is still intact. I had to use some super strength epoxy, because the tiny tube of superglue they sent was not strong enough to bond the two surfaces. The stuff I used probably strengthened the joint enough to make it withstand the pressure.
Re: Check your fix from Breathless! (Mr Dave)
I saw the so called "fix" on a car.
:rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes:
you have every right to be :mad :mad :mad :mad :mad :mad
Regards, Jim :chevy:
[Modified by 89_FX3_6-spd, 2:59 PM 8/7/2001]
