Running 220 Degrees?
We all know C4 vettes run hot, or at least what we think is hot... In the South Florida heat 210 - 220 degrees seemed average for my car, then when it started creeping up to 230 degrees - I started getting nervous. So, last time this happened - I took the radiator shroud apart and grabbed the vaccuum and sucked out all the leaves and debris. Normally, this would be a quick fix - it worked before. This time I put everything back together, started her up and much to my disappointment... 230 again!
Well, the radiator had been flushed, new coolant, added those worthless additives like the glow in the dark purple stuff... nothing worked.
I am proud to say that I decided to add an aftermarket radiator. It was a direct bolt-in, with absolutely no modifications required. The radiator is a work of art! It has metal tanks and looks a lot larger than my stock radiator. Before I mention the brand of the radiator, here's the temps... These temps are with the same water pump and same 160 degree thermostat - only changed the radiator, no other modifications -
Normal driving - 169 degrees!!!!!!
Sitting in traffic - 179 degrees!!!!!!!
Even horsing around town in low gears (automatic tanny) the hottest temperature so far has been - 181 degrees!!!!!!!!!! Haven't been to the track yet, but I can't wait!
Are these numbers scientific? No, I'm just relating the numbers from the dash gauges - and I have no idea how accurate they are, however, I'm using the same gauges for all references (before and after). I kind of believe these numbers have to be somewhat accurate, as my fan rarely comes on anymore.
OK, where did I get my radiator???
RON DAVIS RACING RADIATORS
Yes, they are expensive and yes they make custom radiators for corvettes!! I wish I would have done this years ago!!! This was one of my best upgrades ever!
No, I don't work for them or have any finacial benefit from this post, it's just that I had met another '87 owner who put a different (expensive) aftermarket radiator in his show car - he only gained 5 degrees cooler.
So, if you're planning on an upgraded radiator - do your homework, I did mine. 110% satisfied that I made the correct choice!
My system really never goes above 190/200 coolant/oil during driving, with 180 stat.At hot idle, it will eventually kick on the fan at 228 then drop again, but at the drag strip, I can pull it down to 185 with the fan override, takes exactly 2 minutes.
Well now I know what I'll be doing this weekend. Great article. I kept looking at my shroud and it looked like you had to remove the AC lines to get it off but apparently I was mistaken. So now I think I'm ready to tackle the job. Got the tools got the anti freeze so wish me luck. Oh the only thing I'm missing is the cooler of beer but since its a little chilly here I'll settle for my Coffee and Bailey's Irish Cream.If you have to modify your shroud, a Dremel tool or other rotary tool will do - I had to cut my shroud for an aftermarket air intake system. Easy to do if you have a little patients... remember, measure twice, cut once! Again, my particular application was a direct bolt in. No cutting.
If you're installing yourself (kind of easy for me, and I'm NOT a mechanic) Make sure you plan to have everything in advance such as Thread Tape (you will have to unscrew the 2 transmission lines that go to the radiator - easy to do) Also, check the condition of the coolant level sensor connector! The little plastic ears broke off of mine when I was reinstalling. Mine is located under the fill kneck, it's a single green wire on my application. I simply plastic tied the connector to the radiator until the little plastic connector arrived. Obviously make sure you have fresh coolant and distilled water. I didn't replace mine- but it is suggested to replace the rubber cushions inside the shroud (cheap & easy to do) I didn't think about that in advance, and I wasn't going to wait with my installation. So far no problems. You may / may not want to also get a new radiator cap.
When I received my radiator, it was very nicely packaged with no damage. It came with easy to follow instructions and how to care for this all aluminum radiator including preventative maintenance.
Note: they didn't have my radiator sitting on the shelf, so I had to wait a couple of weeks for them to manufacture it. Your car is newer, they may have one...
Let me know if this helped or if you need more info.
Ron Davis website only claims about a 20 degree improvement in most applications, I'm averaging about 59 degrees cooler from the original 230 degrees.
I'm just sharing my own personal experience with everyone.
Hope this helps...
By the way, your car looks really clean - nice ride and thanks for looking!
By the way, I checked out your photos - nice clean motor and engine compartment.
I leave mine idling, which lets the radiator pump cool coolant through it to pull the heat out. When you shut the motor off, all that heat has nowhere to go, so it just dumps into the coolant and that's when it's under the most pressure and highest temp, and most likely to boil over and leak.
Replacing it with a good aftermarket unit is a good idea.
If a car is 10 to 15 years old a new radiator is the way to go.
As I was trying to state in my original post - this radiator is by far -superior to a factory radiator, it runs coolor and is more consistant, even in changing conditions.
Now, we've basically been talking about racing, however, some of us live in hot climates that affect our regular operating temps. Getting stuck in rush hour traffic in South Florida for any extended amount of time (which is a daily occurance) can be a nightmare... temps can soar 20 - 30 degrees just sitting in traffic with no air flow, add running the AC, headlights and cranking the stereo - and now you sit there watching your engine temps rise and your battery charge drop. Now, I have no fear whatsoever sitting in traffic. One time my temps went up to 181 degrees sitting in traffic, I just smiled and thought what a great radiator and reaffirmed to myself - that this was money well spent!
The bottom line... while most people are trying to get down to 190 degrees, I've never been above 181 degrees (yet) My highest temps are 10 - 20 degrees cooler than most peoples lowest temps.
