quick coolant question...
Old Jan 20, 2006 | 12:23 AM
Shawn_65's Avatar
Shawn_65
Default quick coolant question...
say that 3 times fast...
ok so.. I start my day off driving 30 miles to school and I park and head to my first class. After class I start the car up and the "low coolant" pops up. I restart the car and its gone, I begin to drive and it pops up again. It was about 40 Degrees F. outside. Then I get onto the highway and it goes off. Never saw it again from dinner..to home 30 miles back.
Any thoughts on this one guys? never had this happen to me before. shouldnt the light stay on if i need coolant?
guess it wasnt so quick... sorry
Old Jan 20, 2006 | 12:32 AM
86PACER's Avatar
86PACER
Sounds like you need to add more coolant when the thermostat is open. I need to do that too.
Old Jan 20, 2006 | 02:14 AM
vader86's Avatar
vader86
burp the system
its best to notice what the temperature is when this happens
Old Jan 20, 2006 | 08:02 AM
runner140*'s Avatar
runner140*
Originally Posted by vader86
burp the system
Burp system or low coolant, or both.
Old Jan 20, 2006 | 09:24 AM
CREWZIN's Avatar
CREWZIN
Yep, just went thru that with mine. Was getting "low coolant" on and off at different times. Finally one day at a night Christmas parade the weather turned cold and deceided to put the heater on....only cold air, froze by butt off. Got some great advise from this forum on how to burp the system and everythings been great for the last 6 weeks. Plenty of hot air and no blinking "low coolant" light.
Old Jan 20, 2006 | 10:17 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
As coolant heats up, it expands. If the coolant is just slightly low, it will often expand enough that the sensor then sees it as NOT being low. Hence, the intermittant light. (my VW does this a lot)
Cure: top up the coolant and find the reason it got low.
Larry
code5coupe
Old Jan 21, 2006 | 01:11 AM
Shawn_65's Avatar
Shawn_65
Thanks for all the help guys
I do keep the heater on a lot, so I might of burp'd it, not sure. I think the temp was at the lowest when the light hit. Hasnt come on yet though
Old Jan 22, 2006 | 09:19 PM
Shawn_65's Avatar
Shawn_65
shoot, the coolant light came up again.
can anyone tell me how to burp the system?
I've noticed that my "low coolant" light doesnt come up at startup like the owner's manuel says it should. Could this be bad wiring?
Old Jan 22, 2006 | 09:50 PM
CREWZIN's Avatar
CREWZIN
Just got done doing it last week to cure my "low coolant" light.
Fill up overflow to cold line. Take radiator cap off and start engine. You might have to take a few ounces of coolant out of the radiator so it doesn't overflow while running. Let it run until you can see thermostat open up and collant running. Have 50/50 mix ready. Reach over to the throttle body and turn the butterfly so the engine gets up to about 2000 rpm. The water in the radiator will drop down out of sight. Keep up the revs and with other hand pour the 50/50 mixture into the radiator till it reaches the lip. Still keeping the revs up, grab the radiator cap and screw it on. That's it. Some say you might have to do that a couple times but once was enough for me.
Another point. They told me to jack up the front of the car while doing the above, which I did. Supposedly this gets the water way back into the back of the engine and puts the high point at the top of the radiator.
Old Jan 23, 2006 | 12:40 AM
aminnich's Avatar
aminnich
If you have the LT1 you MUST open the bleeder valves with engine running and also at temp with t-stat open to get air out and coolant in. Otherwise you are just wasting your time.
Old Jan 23, 2006 | 01:29 AM
Shawn_65's Avatar
Shawn_65
Cool I have an L98 so this shouldnt be too much trouble for me. I wont be able to jack it up, but my driveway is a little sloped. but..where is the thermostat located...heh sorry for the stupid question
wish I had a helms manuel. I guess i can just look for the coolant to cycle. thanks again for all your help guys, I probably made this out to be a lot more than it is. My overfill tank already reads cool, so I shouldnt have to add any in there right?
Old Jan 23, 2006 | 01:33 AM
86PACER's Avatar
86PACER
It's located under the throttle body where the upper radiator hose connects. You won't be able to visually see it open. Start the car and let it idle to get hot. By squeezing the upper radiator hose with a rag around your hand, you'll know that the thermostat is open when the hose does not feel hard anymore. That's when you add more coolant while raising the idle like mentioned above.
Old Jan 23, 2006 | 04:14 AM
Shawn_65's Avatar
Shawn_65
Awsome reply!
that makes life a lot easier, thanks pacer
To quick coolant question...
