Vacuum line routing on '90 - Help Please...
On my vacuum canister located on the front driver side of the car underneath the headlight assembly, there are 3 vacuum lines coming out of the top of the canister and one out of the bottom. I know where the top 3 lines go due to the diagrahm on the radiator shroud, but cannot determine what the line coming out of the bottom of the canister is supposed to connect to.
Can someone with a C4 tell me where the line coming out of the bottom of the canister goes to? Thank you in advance Corvette brethren.
mseven,this is a great diagrahm, but it does not show the hose coming out of the bottom of the canister. It just shows the 3 on the top.
Does anyone know where the hose on the bottom of the canister goes?
Correction.......Took a look at the FSM, page 6E3-C3-1, the lower tube on this vapor canister is an "air inlet/drain tube" and should be left open...Diving under the hood with pliers now....
Originally Posted by JeffM1243
Do you have one hose into a tee and two hoses off to nowhere? Open at ends? My 90 was the same, car ran fine with these hoses plugged or unplugged, no codes ...I plugged them anyway....This hose does not appear to be on the emissions schematic....
