Squeaking underneath the car
Old Jan 23, 2006 | 11:16 AM
davidea70's Avatar
davidea70
Default Squeaking underneath the car
I have a '88 coupe and lately there is a lot of squeaking when i go over dips and bumps. The squeak sounds like it is under the car in the front. The shocks are new. Any suggestions on what is could be? Thank you.
Old Jan 23, 2006 | 11:38 AM
Joe C's Avatar
Joe C
http://forums.corvetteforum.com/show...37&forum_id=48
Old Jan 23, 2006 | 03:29 PM
The Gooch's Avatar
The Gooch
St. Jude Donor '06-'07-'08-'09-'10
For a car that old, I would first suspect bushings.
Old Jan 23, 2006 | 08:46 PM
Chewch87's Avatar
Chewch87
I was lucky locating a squeak that was driving me crazy. It was coming from outside....on the left front side somewhere in the area of the corner of the hood and front door. Took me months to finally nail it. Turns out the spring latching mechanism that engages when you close the front hood was squeaking. I fixed it with some silicone lubricant.
No problem since. I am the lucky one because most owners absolutely go batty -out-of their minds trying to find rattles & squeaks.
Old Jan 23, 2006 | 09:01 PM
91DRM's Avatar
91DRM
From: Isle of View "Mofo skated me, that was my up!"
Maybe you'll get lucky like I did and it will just be a loose sway bar bolt.
Old Jan 23, 2006 | 10:59 PM
rightofway's Avatar
rightofway
not to hijack but i have a similar problem but it almost sounds like the air dam scraping but it isn't. would this be a bushing
Old Jan 24, 2006 | 01:21 AM
skeet's Avatar
skeet
You didn't say if it was a Z51 car. If so, and if it mainly happens when it is cold outside then I would say it was the sway bar bushings. Both my 85 Z51 and my 88 Z51 did this when it was cold out. They did it from new to when I sold them. You might want to try a Honda's O-ring safe teflon chain oil that is sold in motorcycle shops - it is safe for rubber.
GM used a harder rubber bushing in their Z51 cars.
Old Jan 24, 2006 | 09:08 AM
rightofway's Avatar
rightofway
you hit the nail on the head there skeet . looks like i'll be gettin some more chain lube
To Squeaking underneath the car
