Burping cooling system
Old Jan 24, 2006 | 10:26 AM
89redone's Avatar
89redone
5th Gear
Default Burping cooling system
89 Vette, 48,000 miles , replaced starter side freeze plug last week, aded coolant to raditator, drive it, add coolant light comes on , done this about three times now goes on and off, have checked again this morning (cold engine) raditator full, noticed in one of the mauals about 92 and previous about burping the system with bleeder valves near the throttle body, did not see anything like this?
Thanks,
Todd
Old Jan 24, 2006 | 10:32 AM
cv67's Avatar
cv67
St. Jude Donor '05
I believe the LT1 cars have them, never seen one on an L98.
Old Jan 24, 2006 | 11:03 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Yea, L98's require burping and reburping till you get it right.
Jack the front end up, open rad cap, start engine, let it warm up to op temp and term opens up, then have coolant mix ready, using the throttle linkage, rev and hold @ 2000 rpm's, you'll notice the level goes down, add coolant till up to neck level, hold the throttle @ 2k for a while to see if it goes back down, if so, add again, when finally you have to add no more, while still at 2k put the cap back on.
It took me 3 times before i finally got it burped completely. Then take it out for a drive and redo the process if necessary.
You might also check the rad cap, i finally had to get a new one.
Old Jan 24, 2006 | 04:07 PM
HeeHaw89's Avatar
HeeHaw89
My thoughts exactly after doing the same thing...it takes a while to get all the air out.
Old Jan 24, 2006 | 07:09 PM
lite blue's Avatar
lite blue
St. Jude Donor '12
L98s don't have bleed valves. Do the procedure that Vinnie said. It's called "packing". Works great.
To Burping cooling system
