Washer reservoir replacement
Old Jan 24, 2006 | 03:47 PM
91polo's Avatar
91polo
Default Washer reservoir replacement
How big of a job is it to replace the washer reservoir in a 91 coupe?The one in the car leaks out completely. Is there an easier fix?
Old Jan 24, 2006 | 10:12 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Are you sure it is the bottle? Mine had a hole in the hose just below the bottle. I spliced in another piece and now it does not leak.
Old Jan 24, 2006 | 11:20 PM
VtVette's Avatar
VtVette
Easy job, just remove the right hand fender. You *may* also have to remove the rear right wheel well liner, I can't remember if there is enough access with it in place to remove the tank.
Old Jan 25, 2006 | 09:47 AM
91polo's Avatar
91polo
Haven't checked the hose, just know that the water runs right thru it when poured in the bottle. I'll check it tho
Old Jan 25, 2006 | 09:49 AM
91polo's Avatar
91polo
I'm sure you're kiddin, the wheel liner I can see but not the fender
Old Jan 25, 2006 | 10:07 AM
87vette's Avatar
87vette
Yup fender needs to come out also. Very easy.
Old Jan 25, 2006 | 11:15 AM
91polo's Avatar
91polo
OK I'll give it a try-thanx
To Washer reservoir replacement
