1984 Fuel Problem
Old Jan 28, 2006 | 09:04 PM
Steve Mitchell's Avatar
Steve Mitchell
2nd Gear
Default 1984 Fuel Problem
I have a 84 vette and when I start the car it runs at about 1500 rpm. It runs for a short time (3-7 minutes) then stops. The fuel injectors cease to pump fuel. After a couple of hours the car can be restarted and will run for a shorter period of time. I have had the fuel pump out and inspected it with no problems. Do you have any thoughts on what might be the cause of this?
Old Jan 28, 2006 | 09:23 PM
Cherry6speed's Avatar
Cherry6speed
Fuel pumps are notorius for intermittent problems. If you are sure the pump is good (new?) I would look at the fuel pump relay, also a very popular culprit for letting you down then changing it's mind. Good luck
Old Jan 29, 2006 | 09:08 AM
Midnite 88's Avatar
Midnite 88
Are you getting fuel pressure when it decides it doesn't want to run anymore?
When was the last time the fuel filter was changed?
Old Jan 29, 2006 | 10:01 AM
Sandrider's Avatar
Sandrider
St. Jude Donor '05-'06
Pump, Inline filter, and I have had several Tank sock filters plug up over the years on GM products....
Old Jan 29, 2006 | 11:06 AM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
check the TB filters as well some time. whole kit from autozone is $44
Old Jan 30, 2006 | 12:36 AM
Frizlefrak's Avatar
Frizlefrak
Time to start troubleshooting once you get the no-start condition.
Set up a fuel pressure gauge priort to starting it. Run it until it quits. When it quits, immediately check your fuel pressure, should be between 9-13 lbs. If the fuel pressure is good, check to see if the injectors are receiving a pulse signal with a noid light.
There are only two reasons why the injectors stop spraying....no fuel, and no power. Find out which element is missing from the equation and then we can figure out why.
Old Feb 7, 2006 | 09:58 PM
Steve Mitchell
2nd Gear
Thanks for the idea. I will try it this week. I feel confident that the fuel pump is OK. I took it out and bench tested it. Also checked the relay as the motor was running. As the fuel flow ceased then the relay clicked (opening?) the circuit.
Where is the best location to install a pressure gauge? Near the fuel hose at the rear by the tank?
Thanks, Steve
Old Feb 7, 2006 | 10:34 PM
js292's Avatar
js292
Best place to install the pressure gauge it to tap in between the two tb's. Do a search on the crossfire injection forum. there are several post on it
Here's a link to the website;
http://www.crossfire.homeip.net/
Old Feb 8, 2006 | 12:45 AM
nelson84's Avatar
nelson84
my 84 did that and some times would rev to 2200 rpm. The coolent temperature sensor was bad, it made the computer think it was 40 below in the summer and would put to much fuel to it and flood the motor. The sensor is on the front of the intake manifold(about $40)
To 1984 Fuel Problem
