hey guys i replaced my starter sat.with a delco it was identical to the one i pulled the old one had a small soft like gasket at the end so i put it on the new one but at the begining of the start i can hear the starter but very little so what sould i do replace that gasket or what?
no it cranks fine now but at the begining you can hear the starter like i have noticed on some older bigger hot rod motors its not really a grinding btu its not quiet like before but its only a millisec it just bugs me and i dont want to damage the flywheel ...
Throw a shim between the block and starter. They are special shims that often come with the new starter. If not they are stocked in a selective pack at most auto parts stores.
thanks after reading some threads here i was leaning toward that.see the old one had that rubber like gasket on it so i pulled it off and put it on the new one but i will check for that shim kit.but one ? how do i know how much shim to put with out putting it on and off so much?
The shims are made to install easily. They have the inner hole slotted. You remove the outer bolt and loosen the inner. Slips right in. Start with a 1/16 and a 1/32. It will probably do the trick. Slip them both in together.
what about the rubber piece in there leave it ?or pull it out?
I am asumming thet the ruber is a seal to keep dirt and water out of the bell. If this is the case, leave it. Then install the shims. They will move the starter down, away from the teeth of the flywheel.
Most new starters come with instructions on how to check if shimming is required. Might want to check your statrer paperwork.
The old shade tree rule was if it sings going in add a shim, if it sings coming out take one out. This referrs to the bendix engaging the flex plate of course.
