I have a 84 that I almost always in the winter have a condensation problem on the inside of the car. I have to use a water blade to get the water off. Any ideas?
From: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
Do you store your car outside is it covered outside is the cover bright or dark in color or is it in a garage is the garage heated (tell us a little more)
It is stored outside. depending on the weather it is usally covered. the weather stripping is new. I was thinking it might be the cover locking in the moisture
Your car acts like a ice cold glass of tea on a hot sunny day outside
The car cover heats up from sun light but the car under neath does not heat as fast and winter days are to short to heat up enough
Where hot and cold meet you get frost and or moisture
I guess I will have to leave it uncovered in a sunny spot or tell my wife hers has to go outside. O n second thought I will find a sunny spot. Need someplace warm to sleep not with the dog!!!
no i dont cover mine and i get the same problem with the condensation. if he means moisture on the seats and so on when its cold out
Do you have a dark interior? that will do it also when the sun is warm and the air is cold!
You would be better off to leave a window part way down to keep the air temprature inside the car as close or same as the outside air temp!
Yes it does have the Carmine color. I will try the window open a crack to see if that helps. Thanks alot to all the forum members. Thats whats nice about owning a Vette. We all help each other out.. KEEP THE WAVE GOING!!!
