Z-52
Old Jan 30, 2006 | 04:26 PM
Grenkepr's Avatar
Grenkepr
Default Z-52
Just found my build sheet. Has a Z-52 suspension. Anyone have the particulars on this suspension. '88 coupe.
Old Jan 30, 2006 | 04:42 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
I'm too lazy to find it in here... but I remember reading it here
Old Jan 30, 2006 | 06:51 PM
88Z51's Avatar
88Z51
From a 1988 Dealer brochure:
Z52 Sport Handling Package.
For the serious enthusiast, the Z52 package includes:
*17" X 9 1/2" cast-aluminum wheels with P275/40ZR17 Goodyear Eagle tires.
*Delco/Bilstein gas-charged shock absorbers.
* Fast-ratio steering gear (13:1).
* Engine oil cooler.
* Heavy-duty radiator.
* Radiator boost cooling fan.
* Reinforced front body structure.
The Z52 Sport Handling Package is available on both Coupe and Convertible models.
Note this information applies to 1988 models. Other years are different.
Old Jan 30, 2006 | 07:06 PM
rws.1's Avatar
rws.1
I believe it also has larger sway bars and a different spring rate....
Old Jan 30, 2006 | 07:56 PM
flyzlow's Avatar
flyzlow
Congrats! the Z52 is the HOT setup. I did not know mine was equipped with that option either until I got it home and ran the RPO codes. Better handling, cooling, and quicker steering ratio. OH Boy!
Old Jan 30, 2006 | 08:24 PM
88Z51's Avatar
88Z51
Not in 1988. The Z52 (1988) used the same springs and sway bars as the base Corvette. The (1988) Z51's got the larger sway bars and stiffer springs.
Old Jan 30, 2006 | 11:35 PM
Pete K's Avatar
Pete K
87 z-52 is the same or similar. Basically, most of the good z-51 type goodies but with the base springs.
Old Jan 30, 2006 | 11:53 PM
Wayne88's Avatar
Wayne88
My '88 has the Z52, according to the window sticker, that option cost $970.
Old Jan 31, 2006 | 04:00 PM
Grenkepr's Avatar
Grenkepr
Thanks for the info. on the Z-52. This is a great forum for an old man like me.
Old Jan 31, 2006 | 05:19 PM
WalkerH's Avatar
WalkerH
I have the Z-52 option on my 87'. I think it is a good compromise for a daily driver.
Walk
Old Jan 31, 2006 | 07:45 PM
88Z51's Avatar
88Z51
Thought you might be interested in this 1988 Car and Driver article on the Z52.
Old Feb 1, 2006 | 07:29 PM
Grenkepr's Avatar
Grenkepr
88Z51.thanks for the car and driver article. It was a neat read,
Old Feb 1, 2006 | 08:45 PM
c4cruiser's Avatar
c4cruiser
The shocks were a bit different too. IIRC, the front shocks were Z51 but the rears were base shocks. There was a slight difference in the size and makeup of the front sway bar.
The 87 Z52 package did not get the p/s steering cooler that came with the Z51 steering. My Service Parts sticker on my 87 Z52 car shows "RPO B1X - Optional Steering Gear Ratio" but the PS cooler is not there. The Z51 PS cooler is a single pass hardline with radiator fins mounted on the front part of the rack housing.
If your Service Parts sticker is still on the underside of the console lid, you can decipher them here :http://forums.corvetteforum.com/show...4&page=4&pp=20 on Page 4 of the thread by Bogus.
Old Feb 1, 2006 | 09:49 PM
Pete K's Avatar
Pete K
I put the z-51 bilsteins on and added the power steering cooler. I bought the last one gm had. It came from Washington State. I always wanted to swap the springs to z-51, but never got around to it.
Old Feb 1, 2006 | 11:19 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Walk
I have the Z-52 option on my `87 also, but I (& my wife) thought the car rode too rough with the stock Bilstiens, so we trashed them for a set of Gabriel gas riders ($20ea on E-bay), & now the car rides great, & handles well.
Old Feb 3, 2006 | 09:46 AM
bluealtered's Avatar
bluealtered
My Z-51 does feel a little stiff but i like throwing it around corners, so it's ok. The c&d story was great, but i missed why they put in the reinforced front end, will someone share that with us. Thanks.
Old Feb 3, 2006 | 06:04 PM
88Z51's Avatar
88Z51
To stiffen the chassis and reduce flex that would change alignment settings under hard cornering. I believe the braces were standard on later C4's.
Old Feb 3, 2006 | 06:12 PM
ZR-71's Avatar
ZR-71
St. Jude Donor '15
16017 cars out of 22789 had the Z52 suspension according to the Corvette Black Book. Later production Z52 cars also had the Z51 finned power steering coolers as well as the larger brake rotors. But the Z51 was the only one with the stiffer springs. One other note, the Z51's were only manual tranny while the Z52 could have either manual or auto trans.
To Z-52
