Bouncing Front End on a 1996
Old Aug 7, 2001 | 07:07 PM
89'Bowtie's Avatar
89'Bowtie
St. Jude Donor '13
Default Bouncing Front End on a 1996
I have a bouncing 96 Vette - really bouncing.
When the vehicle goes over a bump the whole car does a shimmy. You can see the front go side to side. All steering and suspension components have been looked at and seem to be okay.
Some days the car shimmies and some days it does not. It seems as though it does not do it colder tempuratures. When the day heats up, the problem seems to arise.
Any feedback is much needed right now. The car does not have selective ride control.
:confused:
89'Bowtie
Old Aug 7, 2001 | 11:32 PM
MinnesotaWhite's Avatar
MinnesotaWhite
Default Re: Bouncing Front End on a 1996 (89'Bowtie)
Bad shocks...anyone else?? On a 1996 though...do you thrash the car? What is the mileage?
Old Aug 8, 2001 | 12:54 AM
The Example's Avatar
The Example
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Check to make sure that the clips holding the brake pads to the calipers are still in place. That may take care of something. Are the wheels the proper size? Axle?
Old Aug 8, 2001 | 06:50 AM
93 ragtop's Avatar
93 ragtop
Years and years ago, I had a truck that when you would hit a bump (sometimes) it would shimmy and you would have to slow down to get it to quit. Had it checked and no one could find any thing wrong. I took it to a different shop and said the only thing they could find was a slightly worn lower ball joint. Replaced that and it took care of the problem. Good luck
Old Aug 8, 2001 | 12:59 PM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
Default Re: Bouncing Front End on a 1996 (Red 86 4+3)
No clue what it is...:( Mine has nothing of the sort.
Old Aug 8, 2001 | 06:31 PM
89'Bowtie's Avatar
89'Bowtie
St. Jude Donor '13
Default Re: Bouncing Front End on a 1996 (MinnesotaWhite)
I do not thrash the car, the car has 50k miles.
To Bouncing Front End on a 1996
