Wheel clear coat stripping
Old Jan 31, 2006 | 03:15 PM
CORVETTEIII's Avatar
CORVETTEIII
Default Wheel clear coat stripping
CorvetteForum.com is a great place for vette info. So, I have another question. I have a '93 anniversary edition that looks great but the wheels have become somewhat tired. So I want to strip off the clear coat and polish them and then seal them. First, since I am a careful person, can I leave the tires on the rims while stripping the clear coat off? And there are kits out there to strip, clean, polish and seal. But does anyone have any better suggestions to getting these great looking wheels back to new like condition? Second, what is the best wayto clean this particular engine? I know water is bad news for the C4 electricals and distributor area. Someone told me to use clear coat on all the engine parts when it was finally clean. Thoughts???? Thanks to all.
Old Jan 31, 2006 | 06:33 PM
DarkBlue88's Avatar
DarkBlue88
From: Charlotte NC, behind someone going 10 under the speed limit
You can strip, wet sand 600 until the machined ridges are gone, wet sand 800, wet sand1000, 1500, 2000, and polish It took me forever and I've only done 2. I'm doing the 88-89 16" sawblades that few members like. Not sure about clearing them when done, the machined finish helps the clear stick. If the aluminum is clean and not stained under the clear you can re-clear them. The easiest thing to do is leave them if they don't look too bad. mine are/were stained brown/black and one had brake dust melted onto it in a layer, I had no choice. Id like to see some pic's to see if it's worth it. I can email some before and after shots if you like.
Old Jan 31, 2006 | 06:47 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
Go to Pep Boys and get Aircraft Stripper don't get it on the tires or your hands!
Old Jan 31, 2006 | 07:05 PM
myvettesblue's Avatar
myvettesblue
St. Jude Donor '05
and it is not easy expect to spend alot of time polishing
Old Jan 31, 2006 | 07:10 PM
Midnite 88's Avatar
Midnite 88
If we could see the condition they are in right now, we could advise you best. There a few things to take in to consideration. Let me know if you want me to go further into detail.
I have '88 17" "Salad Shooters" or "Quisinarts". Mine were in bad shape when I got the car. The clear had lifted in "trails" and the oxidation had already eaten through the machining grooves, so my only choice was to either sand and polish them or have them re-machined.
It is a long and tedious process to get them to look good but, in my opinion it is worth it. I can also do into detail if you need. Let me know.
Mike.
BTW, I painted inside the air vents the same color black as my car. The rotors and calipers are red to match the stripes.
Old Jan 31, 2006 | 07:18 PM
RICEKILA's Avatar
RICEKILA
My BBS-ish wheels took ( with all the nooks and crannies ) about 2hrs. each--
Old Jan 31, 2006 | 07:59 PM
okies93's Avatar
okies93
St. Jude Donor 06
I recently bought a set off of here. I soda blasted the rear wheels and then sanded the machine finish off. I have one wheel polished and it looks very nice, but I am not going to be happy with keeping them this way. I have decided to have the flat surface and the ring/lip area chrome powder coated. I am hoping to have them done this week. I'll make a new thread with pics.
Old Jan 31, 2006 | 08:01 PM
mikey whipreck's Avatar
mikey whipreck
It's also possible to get the clear coat off by sanding... It takes even longer, but you don't have to worry about getting that Stripper everywhere. It's what I did for the wheels on my '85.
Man that took a long time.
Old Jan 31, 2006 | 09:07 PM
cv67's Avatar
cv67
St. Jude Donor '05
http://forums.corvetteforum.com/show...m_id=34&arch=1
Old Jan 31, 2006 | 09:27 PM
okies93's Avatar
okies93
St. Jude Donor 06
That's been awhile back. How they holding up now? Still looking shiney? I have one wheel buffed out and it looks great but I am not excited about the upkeep of bare polished alu. I am going to try the powdercoat method and am hoping this turns out good.
Old Jan 31, 2006 | 09:35 PM
Rainman15's Avatar
Rainman15
I used paint stripper to remove the clear on my 89's wheels because it had turned white and was really looking bad. Once stripped I washed them thoroughly to remove all the chemicals, dried them for a couple days in the garage then sprayed them with a rattle can of clear coat. It turned out pretty good. I had about 10 hours labor in all 4 wheels combined.
Old Jan 31, 2006 | 09:54 PM
comp's Avatar
comp
to strip ,,,right
Old Jan 31, 2006 | 11:13 PM
mffi115's Avatar
mffi115
Default Nice wheels
Where did you get the wheels?
Old Feb 1, 2006 | 10:36 AM
jfb's Avatar
jfb
I wonder why no one has mentioned using Simichrome for polishing the wheels after stripping. That is the best metal polish I have ever seen.
Old Feb 1, 2006 | 10:40 AM
cv67's Avatar
cv67
St. Jude Donor '05
Those look nice, I like the stock look. I FU'd when stripping the old clear off, left it on to long and scrubbed it off with scotchbrite which scratched the wheels. Thats what led to polishing them
To Wheel clear coat stripping
