Well with the price of gas lately I was wondering if any one uses regular unleaded in their cars? I have never used regular in any of my high performance cars, but I do put it in my truck and my wifes expedition. I would just hate to start having engine problems ie., pinging, knocking, run on.
The guy who owned my '88 before the guy who owned it before me (thank you, CarFax and a lost receipt from 2003!) was using regular in it. I don't know if that is the cause of all of the problems I had with it, but it really was not running well at all when I bought it, and it only had 86k original miles on it! I use the highest octane the gas station has to offer, and I'm too afraid to try anything else. I'd use the middle octane if people have been using it with superb results.
I use regular unleaded in my '85. I thought you were supposed to use it in older Corvettes. Can I use Premium and benefit from it in my car?
This is what I use, and what the manual says to use. The 85s are not considered Hi-performance, they're only rated at 230hp from the factory (8.5:1 compression I think)
The only benefit of premium to a stock engine is prevention of knocking and pinging.
On a modded engine, premium is a must. I am interested what the Vette's are supposed to run. I'm going to be going on a White Castle run once it's nice out(I live 2.5 - 3hrs away from one), and want to calculate cost of the trip. If it's premium, it'll cost a Slider Meal more!
So here is the next question. I too am afraid of the Regular Unleaded Pinging and Knocking, but do you think that one tank of regular would screw everything up enough that I would have clean it all up from the inside?
I know this sounds crazy, but I would hate to be sitting at a light and have some one attempt to race and then have the car ping all the way down the road.
My 88 owners manual states:
"Your engine is designed to operate on premium grade unleaded fuel. However, with the electronic spark control system, you may use either middle or regular grade unleaded fuel at slightly reduced acceleration performance."
It further states:
"You should use a premium unleaded fuel with an octane rating of at least 91. You may use a middle grade unleaded fuel with an octane rating of at least 89 or a regular grade unleaded fuel with an octane rating of at least 87 at slightly reduced acceleration performance.
Using unleaded fuel with an octane rating of lower than 87 may use persistent, heavy spark knock."
When I first purchased my vette, I used premium fuel. After about a month I swapped to regular and never noticed any difference in fuel economy, performance, or problems. Been using it ever since w/ no knocking, pinging, or other issues.
jrzyvet, you have an '85, right? I started off running premium in my '85 but dropped down to regular. As mentioned, our 85s have lower compression and don't need premium (check the owners manual to see it recommends regular fuel). Running premium in an engine that doesn't need it is actually harder on it. I haven't had any issues running regular.
I have an '85 and the previous owner said he's always used regular unleaded (87) and thats what I use. It runs like a dream and is very clean too. I dont experience any kind of knocking or pinging. I would have to agree with what was said about the compression ratio. The higher compression ratio engines should use a higher grade of fuel.
From: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
the 85 has 9:1 compression.
from what i saw on the goggle box the other day, the real need for the higher octane comes in when you stomp on it to stop knocking.
it's probably ok to run regular (especially in a lower cr head), untill you jump on it full throttle, get a little knock and get timing retard at the time you least want it.
come to think of it, running regular would probably be best on a long distance trip--both for economy and the reduced need for wot stomps.
I stand corrected ( My car's in storage right now, don't have the manual so I guessed. Looked it up in my Chilton Catalog - 9:1 for '84 thru '89, then 10.5 and up for the rest)
Guys guys, I don't know how many times this has been explained. There's another thread on this here also. The reason for different octane gasolines is THE RATE AT WHICH THEY BURN!!!!
Higher octane gasolines burn slower than lower octane gasolines. Corvettes are engineered with higher performance therefore they have a different TIMING CURVE, therefore they require HIGHER OCTANE FUELS to decrease detonation. Follow your owners manual if you are not car savvy.
It has been said though that some corvette owners can get away with lower octane sometimes and only suffer a decrease in performance. Maybe your one of them. I wouldn't risk a hole in a piston to save a few bucks. Its up to you. By the time the detonation occurs it could be too late.
You bought a rocket. Feed it rocket fuel
It further states:
