Drivers side window problem
Old Feb 6, 2006 | 11:14 PM
Chad072's Avatar
Chad072
Default Drivers side window problem
My drivers side window started acting up today. It's always gone up a little too far, but that never bothered me because I could just touch the down button and it got to the correct position. Today, I was driving and noticed that a lot of wind noise was coming in and low speeds, so I stopped to check it out. What looks to be happening is the front of the window gets caught, causing the rear to go up and the window uneven in the up positon. I looked around inside with a flashlight, but couldn't see much. I tried to take the door panel off, but didn't know how and didn't have access to a computer at that time. Has anything similar happened to anybody else?
Old Feb 6, 2006 | 11:53 PM
kopbet89c4's Avatar
kopbet89c4
You window stop tabs are out of adjustment. If you remove the interior door panel, you'll see that the bolts are either loose or the tab is just bent. When I last adjusted mine, I had to move the tab downward to prevent the top of the window from hitting the B-pillar and closing on the top of the targa weatherstrip.
Old Feb 7, 2006 | 12:02 AM
Chad072's Avatar
Chad072
Thank you for responding. What's the best way to remove the door panel?
Old Feb 7, 2006 | 12:12 AM
kopbet89c4's Avatar
kopbet89c4
There are phillips head screws all over the panel. Try and make sure you remove all of them. Unbolt/unplug the wire connection harnesses. Then wiggle the panel over the manual lock/unlock lever. Then it is out. You'll see 2 bolts that are slightly larger than the rest of the bolts. Those bolts are the ones that you will have to adjust. I think its like a 9mm size, not sure. Might take a couple of trys to get them adjusted. There are those bolts for the front and rear part of the window. Make sure you don't over tighten them or they can strip. I'd say tighten them up to 15 ft-lbs and they are on and shouldn't be loosened anytime soon after adjustment.
Old Feb 7, 2006 | 04:22 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Pop out the round things at the bottom of the door.
Very carefully remove the lense bar that is the night light ,their is a bolt./screw, you will have to remove.On the unlock arm put it in the open posession and pry the end with a small screw driver.
Becareful not to crack the square black bezzel that houses the light and lock,unless yoiu have 30.00 and can find a place to recoat it.
The bolts for adjusting the door are 10 mm.You have the slides at both ends and check the window guide at the very front of the window if it is cracked replace it or the window will not adjust properly.you have an in and out adjustment in the center ,also you have felt guides they also need to be adjusted .Take your time and dont losen all the bolts at the same time.When removing door panel and installing window must be in the down posession.
Be careful when you unlock the connectors for the wiring ,if you break them you have to buy the whole switch.
Old Feb 7, 2006 | 02:46 PM
Chad072's Avatar
Chad072
Thanks guys, looks like I have a weekend project.
To Drivers side window problem
