4+3shifter question ALSO sensor fitting question.
Old Feb 7, 2006 | 08:24 AM
CoffeeDrip's Avatar
CoffeeDrip
Default 4+3shifter question ALSO sensor fitting question.
Can someone with a 4+3 tell me how the shift lever tabs on the trans are arranged? Is the bigger one on the front or middle? The reverse one is fine(farthest back)
I cannot get the car to go into Neutral in any forward gear. From Reverse to Neutral is fine. I can get all the gears fine but it will not settle into neutral.
Before I go trying to adjust rods, I need to know if I have the tbas on correctly. I have tried searchs for pics but come up empty.
Also. Does anyone know where I can find the harness connectors? Mainly for the mushroom shaped connector for the sensor on the passenger side head. The guy that redid my harness put on a spade terminal when I needed the knock sensor type connector.
Thank You for any info.
