Dash Question
Old Feb 8, 2006 | 10:39 PM
mpcorvette's Avatar
mpcorvette
Default Dash Question
Anyone know how to fix this...
The space that appears over time between the dash and the side console panel on the passenger side. I am talking about the area where the two meet just to the right of the radio. Mine has seperated over time as I'm sure many have. New dash and side console panel or is there an easier and hopefully cheaper fix???
Old Feb 9, 2006 | 12:23 PM
mpcorvette's Avatar
mpcorvette
Anyone???
Old Feb 9, 2006 | 01:45 PM
1quik91's Avatar
1quik91
I had that happen on my 91 and you will need to remove the radio to fix. You will find on the corner of the right panel is a small washer attached to the panel, it attaches to the metal frame that holds the radio in place. I at least had a portion of the washer left, it was broke in two. I used epoxy to attach another washer to what was left and reattached it to the metal frame with a screw. It's been a couple of years and still keeps the panel in place. Hope this helps, it was cheap fix anyway. Good luck!
To Dash Question
