My car is leaking a slight bit of oil. Nothing to be a great concern, but I would like to fix the problem. Where do the L-98s typically tend to leak? The car has 72000 miles on it. I took a look the other day, and I didnt see much. This might have to do with the -3 weather conditions in the winter. But it was leaking when I put the car away for the snooze.
From: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
Do you use synthetic oil?
and the L98s are known for leaking oil around the intake manifold my coupe does not I just rebuilt it but the roadster has a small oil leak it seems to be comming from that area but it had synthetic oil in it so I drained it and put regular 10-30W in just before I put the car away for the winter so I have my fingers crossed that does it or I will be pulling the intake manifold and resealing it
First off make sure it's motor oil; if so:
-Front/rear of intake base & intake base bolts
-oil filter, oil pan
-rear seal
-valve cover gaskets
-oil pressure sensors on the stalk behind intake base
-oil temp. sensor near oil filter
I do use synthetic oil. Do you think changing to conventional will really help?
Years ago on my exwife's 78 olds I put synthetic oil in it and it started leaving oil drips here and there so I put the standard oil back in the next oil change and it quit leaving its oil on the ground
So I am hoping my roadster does the same
I have been told synthetic oil is thinner than regular oil and it finds its way around and through cork gaskets
I run synthetic in my coupe and I have no problems with leaks but it has mostly all rubber gaskets
That is a complete myth about synthetic oil. I run synthetic in all of my cars. 96 Vette, 68 GTO, 70 GTO, etc, and synthetics do not cause leaks nor do they seem to seep through gaskets. I would not change from synthetic back to dino oil, there are too many positives for using synthetic.
-rear seal
YES, those are the biggies. If you have an oil cooler , the "O" ring between the cooler and filter housing is another.
If everything is sealed correctly and you use good silicones/gaskets (right stuff etc.) I don't beleive in the synthetic oil as causes for leaks. MO
