Engine Compartment Lights
Old Feb 9, 2006 | 10:15 PM
daca's Avatar
daca
Default Engine Compartment Lights
Can't seem to figure out why my engine compartment lights won't work. The bulbs look ok. Are they on a separate fuse?? Thanks for help.
Old Feb 9, 2006 | 10:29 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Make sure they are plugged in. There is a separate weather proof connection for each light. A previous owner may have disconnected them if he was in the habit of leaving the hood opened for extended periods.
Old Feb 9, 2006 | 10:31 PM
deerra's Avatar
deerra
Sometimes the previous owner will unplug the lights.
Follow the wires down to the left and right front, to the left and right of the radiator. Should be a plug down there on each side. Make sure it's connected.
Good luck.
Old Feb 9, 2006 | 10:32 PM
deerra's Avatar
deerra
jrzvette
Great minds think alike.
Old Feb 9, 2006 | 10:33 PM
SmokinBlack's Avatar
SmokinBlack
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
C4 of Year Finalist (stock) 2019
St. Jude Donor '08
I keep mine unplugged all the time. Check and make sure that they previous owner didn't leave them unplugged.
Old Feb 9, 2006 | 10:34 PM
SmokinBlack
St. Jude Donor '08
Originally Posted by deerra
jrzvette
Man..you have to be fast around here anymore... Nothing like all of us thinking the same thing at the same time.
Old Feb 9, 2006 | 10:46 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
There is also a 10 Amp fuse for the under hood lights. It is located under the hood, towards the front in front of the drivers side wheels. It is in a sealed connector.
Old Feb 9, 2006 | 11:26 PM
Cozmo's Avatar
Cozmo
One thing that I forgot to mention, some folks take out the fuse for when they have the hood up for long periods of time. Like car shows and when working on the car to avoid battery drain. If you can not find the fuse holder, let me know and I'll snap a pic for ya.
Old Feb 9, 2006 | 11:31 PM
Fork501's Avatar
Fork501
I'm actually having the same problem. The lights on mine worked. I pressure washed the engine. Now they don't work =(
They're plugged in and everything.
I thought the fuse in the engine compartment was on later-model C4s. I have an '88
~Derek
Old Feb 9, 2006 | 11:35 PM
Cozmo's Avatar
Cozmo
~Derek
I have no clue what year the person who started this threads car is. That info would be helpful. I have the fuse on my 96. I am not sure what year they started that.
Old Feb 10, 2006 | 12:18 AM
flyzlow's Avatar
flyzlow
Wow, I might actually be useful here! If the fuse is in and good and the connectors are plugged together then it could be one of two things. I had a guy fix mine at the National NCRS convention in Utah this past July. If you are reading this, thanks again! Since one of you said you pressure washed the engine I am going to guess the same fix for both cars. Water tends to get into the area where the connectors are and corrode the connectors just enough to short them out. Take them apart and thoroughly clean the brass connectors and see if that works. My left one was really bad and I had tried eveything else. If that doesn't work there is a little egg shaped thingie{ whatever ] next to the bulb that can be snapped out and replaced. I only had one light out so I swapped the one from the working light to see if that fixed it and it didn't, so that ruled it out on mine and that is when the I got the help on the corrosion inside. Mine is an 87. Good Luck , I hope this helps. Flyzlow
Old Feb 10, 2006 | 02:23 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Just information...The "little egg shape thingie" that flyzlow speaks of is a mercury switch. It is filled with mercury and completes the circuit when tipped as in when hood is open. They dont often fail but corrosion around them does happen.
Old Feb 10, 2006 | 03:36 AM
flyzlow's Avatar
flyzlow
Thanks for the clarification! I couldn't remember exactly what that thing was. Anyway, your white Vette is beautiful and showcased in front of a beautiful home too. I checked out your website and you have a really cool business. Good luck and have a prosperous new year.
Old Feb 10, 2006 | 10:22 AM
daca's Avatar
daca
Sorry about that My car is 1994.
Old Feb 10, 2006 | 04:41 PM
skateparkdave
Thanks man, from what I can see in your little avatar pic, your white vette looks good too. And Good luck and have a prosperous new year to you also.
Old Feb 10, 2006 | 04:48 PM
vetteboy88's Avatar
vetteboy88
If they have never worked, look for one of those eckler toggle switch kits that some install to manually turn on/off.
Old Feb 10, 2006 | 04:52 PM
Cozmo's Avatar
Cozmo
No problem. You should fill out your profile with as much information as you feel comfortable sharing. Your location and year car would be very helpful to us.
If you can't find the fuse that I spoke of, pm me and I'll post a pic.
To Engine Compartment Lights
Old Feb 10, 2006 | 04:53 PM
Cozmo's Avatar
Cozmo
It's a white Fiero GT. I made that same mistake and asked him once what kind of body hit he had on his vette.
Old Feb 11, 2006 | 01:30 AM
skateparkdave
Dude, I swear I was thinking that but didn't wanna say it. It looked too short but I thought is was one of those scrunched up pics. I guess thats why it looks like a Fiero. Because it is. Does the "GT" make it a 2m6? Those little puppies were pretty quick.
Old Feb 11, 2006 | 02:08 AM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
You da man Longhorn. That's exactly where it is on my 95. At my first show ZR ONE showed me where the fuse was so that I wouldn't drain the battery
