Smoke At start up
Old Aug 9, 2001 | 11:12 AM
vettes's Avatar
vettes
Default Smoke At start up
What does smoke at start up mean.When the car sits a day or 2?Then its ok.
Old Aug 9, 2001 | 11:27 AM
scorp508's Avatar
scorp508
Valve seals are on their way out, allowing oil to sneak into the combustion chamber. Typical Chevy SBC problem, nothing to really worry about unless it embarasses you.
84corvette's Avatar
84corvette
Default Re: Smoke At start up (vettes)
Sounds like valve stem seals -pretty common in high mile cars. Not really anything to worry about unless it is excessive. What you may be seeing is steam from moisture condensing inside the exhause that vaporizes at start up.--even less to worry about!!
Old Aug 9, 2001 | 11:53 AM
vettes's Avatar
vettes
I just had the heads rebuilt last month.w/ new roller rockers. :mad
Old Aug 9, 2001 | 01:58 PM
Lv2Driv's Avatar
Lv2Driv
It did embarrass me so I spent $700 on fixing it. (the rest of the car looks great) Thought of replacing the seals myself but did not have a tool to keep the valves from falling into the block. Repainted my valve covers also. hefty price but i figure on going another 75k with her.
Old Aug 10, 2001 | 12:09 AM
No Go's Avatar
No Go
Is this blue smoke or black?
I've noticed LT1/LT4's tend to pump a bit of black smoke at startup-slight rich condition-seems common and normal. This is barely perceptible mind you.
Sounds like this is blue-I would agree that it is valve guide seals/guides. May want to investigate on exactly what they did to the cylinder heads-surely they would replace the seals...:(
To Smoke At start up
