Diff oil
I only got about a quart and a half of oil in. Does this sound about the right volume?
I can't find anywhere in any of my books any reference to capacity.
I couldn't get two quarts in mine and I removed the batwing. I guess it's due to the fact that the rear axle capacity is 1.5qts/1.42L and 4 oz/118 ml of limited slip additive.
Mike
Wisconsin this weekend. I will use Amsoil synthetic severe
gear 75-90wt.
Is the LSD additive necessary or should I wait to see if I get
chatter in the rear end after changing?
Thanks,
Craig
I added the required amount of LSD additive, even though the mobile synthetic gear lube I used said, that it did not need LSD additive.Mike
gear 75-90wt.
Thanks,
Craig
The additive is necessary, but... the AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 comes with additive pre-mixed in, so you shouldn't need an extra bottle. If you diff chatters, then you can add some.
While it won't hurt to add a bottle if you diff doesn't need it, it will result in the friction plates in the diff having less friction, thus your diff will have less limited slip than designed. Might not be a problem for a daily driver, but if you want maximum acceleration such as for auto-x, road racing, hard street driving or at the drag strip, you will want your diff to perform as designed. If you add an extra bottle of additive when it is not needed, the tire with lower grip will get more torque (where you don't want it) than designed.
Here is the actual AMSOIL note on the additive:
"NOTE: AMSOIL Synthetic Gear Lubes do not require the use of this additive. However, not all differentials respond the same and if chatter is noticed, the addition of AMSOIL Slip-Lock will eliminate it. For chattering differentials not running AMSOIL Gear Lube, this product is an excellent solution to the problem."
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Gordon Kilibrew "THE C4 GURU" advises to add two 4oz bottles of the GM posi-lube....
He said the same thing in a class I was in. He had also advised Mobil 1 synthetic gear oil.
I did that when I changed my diff fluid. Cheap insurance.
The new stuff I put in was Castrol synthetic. I used a additive from NAPA that was not true GM but it was for that purpose. Once I get it back on the road we'll see if it chatters or not.
