Bosch sparkplugs
Old Feb 12, 2006 | 07:06 PM
C4driver99's Avatar
C4driver99
Default Bosch sparkplugs
I know this is probably a stupid quiestion but im curious. Do the Bosch Platinums +4. I was wondering if they add horsepower or are better than the AC Delco plugs. They have 4 bottom pieces and are pregapped? Better performance??? Thanks
Old Feb 12, 2006 | 08:14 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Before I changed the plugs in my 93, I did a search and found that very few people had anything good to say about the Bosch plugs. I went with AC Delcos.
Old Feb 12, 2006 | 08:27 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
had a set of bosch's, pulled them out with less than 1k on them. talked to others, they did the same. i went to split fire plats
Old Feb 12, 2006 | 09:43 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
AC Delco's will do fine.
Old Feb 13, 2006 | 08:42 AM
blown87's Avatar
blown87
GA Events Coordinator
bosch plugs are great in a BMW or a Volvo or MB, but AC is better for your Corvette.
Old Feb 13, 2006 | 09:21 AM
rws.1's Avatar
rws.1
It seems there are mixed opinions....
I am thrilled with the Bosch Platinum +4 in both my Vettes.
Instant start-up, Much smoother idle, no hesitation... than with the stock AC's I replaced.
Add to that the life of platinums and I won't be busting my knuckles again for quite some time.
Rich
Old Feb 13, 2006 | 09:38 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Spark plugs cannot increase torque (power).
Unless it's a case of replace old/fouled/improper plugs with new/correct ones, in which case you're just getting back to baseline.
Larry
code5coupe
Old Feb 13, 2006 | 10:06 AM
mseven's Avatar
mseven
Larrycode5coupe
That's what I think, but all the propaganda from co.s like tpis "gain 4 hp" etc. doesn't help. If we all went by more money in spark plugs =faster/better I'd be buyin the denso's....should be even better right
Old Feb 13, 2006 | 11:55 AM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
Rich
although I only have the +2s.
No power increase, just better/longer lasting than normal plugs.
Old Feb 13, 2006 | 12:15 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I like the NGK TR-55 Platinums.
Old Feb 13, 2006 | 12:53 PM
redwing76's Avatar
redwing76
The average plug will last 100k. The leaded fuel was what killed plug life. With each 25k of miles the gap will increase eventually becoming to big for the spark to gap.
With todays HEI ingnition system any plug will do, there are no super plugs.
Old Feb 13, 2006 | 02:02 PM
95PoloVert's Avatar
95PoloVert
Active Streak: 90 Days
Larry
code5coupe
Cut-back and indexed single-electrode plugs are worth a few HP, if you're willing to put in the time to do it.
Old Feb 13, 2006 | 04:27 PM
rocco16's Avatar
rocco16
Indexing can give fractional gains.
Cut-back plugs do nothing, at least nothing that can be measured.
Until someone can produce multiple, back-to-back dyno runs that show otherwise, I'll stand on that.
Larry
code5coupe
Old Feb 13, 2006 | 04:38 PM
C4driver99's Avatar
C4driver99
thx guys that was helpful. I guess its just preference.
Old Feb 13, 2006 | 05:00 PM
tnt-sportfishing's Avatar
tnt-sportfishing
Something to ponder. I have talked to a few mechanic's on the subject of spark and fuel. My question was related to the LT1. In regards to fuel I was informed that the motor was designed with regular 89 and 91 octane in mind, the high the octane the less fuel will have a chance to ignite properly causing unburned fuel in the cylinder and poor combustion. Thus inconjucntion with a +4 plug and high octane you will not get full or proper ignition in the cylinder. This I presume is all thought of when the ECM was programed. With this in mind I would imagine that the +4's would be good in a carburated motor. I have the +2's and run mid grade 91 octane with no problems. Does anyone else have info on this?
Old Feb 13, 2006 | 05:15 PM
95PoloVert's Avatar
95PoloVert
Cut-back plugs do nothing, at least nothing that can be measured. Until someone can produce multiple, back-to-back dyno runs that show otherwise, I'll stand on that.
Indexing the plug and cutting-back the electrode both work toward the same valid goal...to unshroud the spark.
Gains from both added together don't generally exceed 1-2% though...which is pretty close to the limits of dyno-resolution.
Someone around here has done a series of back-to-back testing, and picked up a reproducible 1 mph trap speed on cut-back plugs alone on an L98. Myron Cottrell from TPiS claims 5-8 "dyno-proven" hp on LT1s.
If you have a bench-grinder setup, it only takes a few minutes. Downside is reduced plug life.
Old Feb 13, 2006 | 05:19 PM
C4driver99's Avatar
C4driver99
I run 93 in mine and the previous owner installed +4s in mine. Thats why i was asking. I hope this does not mess anything up.
To Bosch sparkplugs
Old Feb 14, 2006 | 08:27 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
St. Jude Donor '05-'06-'07
I use NGK in the C5 StuzVette...
...I would go with NGK if they are a plug of choice on the C4
Old Feb 16, 2006 | 07:43 AM
robertt43's Avatar
robertt43
Default Nothing good to say about Them
Not worth the trouble,stay with factory plugs. If your system is right,high volt coil.msd wires,high output module,good connections,brass terminal cap,your getting everything there is to get.....
Old Feb 16, 2006 | 08:03 AM
torkman15's Avatar
torkman15
The spark only takes the path of least resistance, so you can have 25 electrode tips in there and the spark will still find the path of least resistance meaning one is all you really need. I know people who build twin turbo and supercharged engines for a living with state of the art facilities who say one electrode is all you need. Sparkplug makers need a gimmik to get certain people to buy there stuff better or not.
