AM/FM cassette replacement
Old Aug 9, 2001 | 05:10 PM
pacer's Avatar
pacer
5th Gear
Default AM/FM cassette replacement
I would like to replace the factory AM/FM cassette player in my '94 coupe with an aftermarket CD player. After searching for awhile, it seems that nobody makes a player that is narrow enough for the standard dash opening. The tech people at Crutchfield said too much cutting is required, and these guys have installation kits for everything! Has anybody out there ever replaced their factory system?
Old Aug 9, 2001 | 05:16 PM
Scoob's Avatar
Scoob
Default Re: AM/FM cassette replacement (pacer)
Welcome, pacer.
There is an audio section here on the forum. Post your question over there. You'll get a lot more response in that section.
Old Aug 9, 2001 | 05:59 PM
CG77VETTE's Avatar
CG77VETTE
Pacer,
The Bose speakers only work with Bose stereos since they are amplified at each speaker. In order to use an aftermarket unit, you have to replace all the speakers as well. There are several plug-in units that work with the Bose speakers sold through Eckler's, Corvette Central and Mid-America. Some Forum members expressed some dissatisfaction with these units. I replaced my unit with a GM refurbished factory GM Bose AM/FM CD that was an option in the '89 Caprice Classic. Simple plug in and perfect fit. I paid $475 for the unit at my local Chevy dealer. Little expensive but it worked for me. Hope this helps. You will get alot of additional advice in the audio section.
Old Aug 9, 2001 | 06:17 PM
XTwinTurbo's Avatar
XTwinTurbo
Default Re: AM/FM cassette replacement (CG77VETTE)
I've replaced the AM/FM cassette factory deck from my '94 with a standard DIN video display and controller from Clarion. There was no cutting involved and I've also kept my stock speakers (Bose gold).
You will need to build your own custom brackets to keep the stereo mounted in the middle of the dash aswell you'll need to custom cut a cover for the Vette's larger DIN. As for the speaker wiring, I picked up a convertor from Walmart (~$20 USD) that coverts the speaker voltage from my head unit to BOSE setup.
It runs great with my DVD player and Playstation but I haven't cranked the stereo past half volume for fear of blowing the bose speakers.
I'll try to post pics later on today.
P.S. Don't ask how I can get a DVD player and Playstation and CD-changer into my ragtop. I can tell you it all has to come out when I go shopping.
Old Aug 10, 2001 | 12:01 AM
Speed-Racer's Avatar
Speed-Racer
Default Re: AM/FM cassette replacement (XTwinTurbo)
Cutting that plastic is too risky.
Could'nt GM have designed it normally like the ealier C4's?
GS
To AM/FM cassette replacement
