85 Alarm Problem
Old Feb 14, 2006 | 01:41 PM
racer69's Avatar
racer69
Default 85 Alarm Problem
My 85 will ocasionally sound the alarm when I open the door. I have to raise the hood and disconnect the negative battery cable to reset it. Can someone tell me what the problem is?
Old Feb 14, 2006 | 02:15 PM
rons85's Avatar
rons85
Inserting the key in either door lock and locking/unlocking that tumbler should cancel the alarm. Key in the ignition will NOT cancel the alarm. The alarm is Armed by locking either door from the outside with the key. You should verify the operation of the switches on the door locks - these can fail....
Old Feb 14, 2006 | 03:39 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It's most likely the door locks not grounding out the theft disable line. Does it happen on the drivers or passenger side, or both?
As far as the key not disabling it.... The GM book says turning the key on will disarm the alarm, but it won't kill the horn once it's already been tripped.
Here's all the TDM stuff:
Old Feb 14, 2006 | 03:59 PM
Muffin's Avatar
Muffin
This is what I have to do. Passanger door to be exact.
Old Feb 14, 2006 | 07:54 PM
dmorris's Avatar
dmorris
The control module is under the dash top behind the breadbox. The absolute best mod I did to my 85 was to yank that puppy out. A blue box about the size of a pack of smokes. Disconnect the wires, no more psycho alarm. Also a good time to do the breadbox delete.
Old Feb 14, 2006 | 08:24 PM
RichardR63's Avatar
RichardR63
Cruising
Default Richardr63
I have the same problem with my 86 driver's side door. I have been fixing other problems on my list and haven't gotten to this one yet this winter. I'll post how it went.
Old Feb 15, 2006 | 09:54 AM
racer69's Avatar
racer69
Thenks everyone for the ideas. Can you just pull the module on the 85? I really don't want that alarm on this car anyway.
Old Feb 15, 2006 | 10:09 AM
rick lambert's Avatar
rick lambert
Best thing I ever did was get rid of that POS stock alarm and
went with an after market keyless entry-with a ton of options.
Got it at Best Buy-AVITAL model 2200. That was about 4 or 5
years ago-trouble free.Think it was around $250 installed and the guys were really professional.
Old Feb 15, 2006 | 05:12 PM
CentralCoaster
It's much easier to just unplug the module.
But why don't you just pull the door panel off and clean the door lock switch?
Old Feb 15, 2006 | 07:15 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
you can also just take apart the DIC and pull the fuse.
Old Feb 16, 2006 | 12:55 AM
CentralCoaster
That'll do it to. You'd lose the horn with it though.
Old Feb 16, 2006 | 03:32 AM
November Soul's Avatar
November Soul
I have manual envy, mine isn't in color
Old Feb 16, 2006 | 01:51 PM
racer69's Avatar
racer69
I don't really want to pull the door panel, because I think the stock alarm system is cheesy on the 85's. I think I will just disconnect the module, and have a nice alarm installed with the keyless remote. Living in Colorado, the few cold days can freeze the outside locks.
Old Feb 16, 2006 | 02:36 PM
November Soul
Speaking of the locks, on the driver's side mine is really really stiff, and too much for my wife to deal with :o ... is there any way of fixing the stiffness?
Old Feb 16, 2006 | 03:58 PM
CentralCoaster
The only thing cheesy about the GM system is the lack of keyless entry.
Your aftermarket one is otherwise going to function the same, and hook up to the same inputs. It will probably be easier to defeat than the GM alarm, which requires locating the module or removing the dash to get to the fuse.
And if Circuit City installs it, your aftermarket one is more likely to fail or set your car on fire.
Old Feb 18, 2006 | 04:19 PM
flannel_man
strange, my horn still works
To 85 Alarm Problem
