Thinking of cleaning my car cover my wife goes to work tomorrow and thinking of putting it in the washing machine ( hopeing she doesn't find out) can you clean one this way or will I be making a trip to sears.Its a max tech I believe its flannel
They say they are machine washable, if you are worried about it go to a coin laundry. I did the same with the dishwasher on my build up and the oven to cure parts........she never found out
Unless you have a large capicty washer, you may want to take it to a laundry mat. The large washers at the laundry mat will tumble your cover instead of working it back and forth, this will keep it from tangling up. Hope this helps.
Also mseven's post.
Use the Coin-Op.
Never play with the Queens' toys, Just as you wouldn't want your SO using your car to dry rugs on.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
What they don't know won't hurt them! Is the dishwasher a good parts cleaner? I may have to buy one if that's the case.
