Problem with voltage meter?
Old Feb 18, 2006 | 12:57 AM
tinman332's Avatar
tinman332
Default Problem with voltage meter?
My 91 Vette generally runs with the volt meter well ABOVE the halfway point. I drove it for an hour on the highway tonight and then when I went back to more stop-and-go type driving, the needle was buried in the highest range of the gauge, causing the red battery light to come on. After about three hours, drove home again on the highway for an hour and then got back to city driving and the same thing happened. It continued to run fine during all of this, but is this a problem of "over-charging" the electrical system or what?
Anybody else have a similar problem or some advice for me?
Thanks,
Barry
Old Feb 18, 2006 | 09:45 AM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
Thanks,
Barry
I've had a similar problem, not with the car, but with a Motorcycle. It was the voltage regulator gone bad, and I ended up toasting the battery by overcharging it. When I measured the output of the regulator, I was getting 23V to the battery.
If you have a Voltmeter, measure the Alternator output right at the positive battery terminal next time you notice it. This will tell you if its the gauge or the alternator.
Old Feb 18, 2006 | 10:58 AM
jfb's Avatar
jfb
The alternator output should not exceed 16 volts. Also, one of the functions of the red battery symbol light is to indicate excess voltage. You can overcharge your battery and damage it, so if a separate voltmeter indicates more than 16 volts, then it is time for a new voltage regulator in the alternator, or a new alternator if you don't want to mess with it. Another solution is to take the alternator to an auto electrical shop and they can install a new voltage regulator and check out the rest of the alternator.
Old Feb 18, 2006 | 12:39 PM
mikeb's Avatar
mikeb
Personally, I'd just replace the whole unit (if that's the cause of the problem). I don't see it as being worthwhile just to replace part of the unit when you can get a 1 year or lifetime gaurantee depending on the seller.
To Problem with voltage meter?
