Door Panel question
Old Feb 18, 2006 | 10:32 AM
Gazpar's Avatar
Gazpar
Default Door Panel question
I have an 86 vert, that is in decent shape, but needs some finishing touches.
In shopping around for door panels, I'm getting SEVERAL vendors telling me that there is NO diffrence between the coupe and 'vert door panels, although Ecklers, MAM, wilcox and others have diffrent part numbers and prices for them. ('vert panels are $30-50 more)
What is the diffrence, and are all (84-89) door panels generic?
Thanks for your help
Old Feb 18, 2006 | 11:29 AM
rick lambert's Avatar
rick lambert
They are the same! nothing changed from the window down and
door dimensions are the same.
Old Feb 18, 2006 | 11:53 AM
torkman15's Avatar
torkman15
Vert prolly dont have a hole for the hatch switch.
Old Feb 18, 2006 | 12:05 PM
rick lambert
hatch switch is in the door by the striker-not the panel.
Old Feb 18, 2006 | 12:11 PM
kize's Avatar
kize
Hum, interesting. I had to cut holes in my new door panels to install factory hatch release switches. Are you sure about this??
Old Feb 18, 2006 | 12:22 PM
VtVette's Avatar
VtVette
The black trim piece that rides along the top of the door panel is different from Coupe to 'vert. Usually when you buy a new door panel it does not come with this piece, you reuse your existing one. The door panels themselves are the same though. If the panels you are looking at come wiht the black trim piece along the top of the door panel than you will need 'vert specific.
Hope this helps,
Old Feb 18, 2006 | 12:45 PM
rick lambert
My humble appology-just went out to look (guess my memory is worse
than what I remember) yes, the hatch switch is on the door panel
plastic portion-it is however concealed when the door is closed. Once
again-sorry for the bad
Old Feb 18, 2006 | 12:51 PM
rick lambert
Had to just go out and look (memory must be worse than I remember ) you are right-I appologize-the hatch switches are
located in the plastic-concealed when the doors are closed-I haven't
used any of the hatch switches since new alarm with keyless controls
my hatch as well-once again-sorry but I believe all else is the same.Just duped
Old Feb 18, 2006 | 04:54 PM
86Pacecar's Avatar
86Pacecar
Hope this helps,
The only difference is the top black trim piece. I got mine from Willcox, best price and great customer service.
Old Feb 18, 2006 | 08:29 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
My are also on the door by the striker.
To Door Panel question
