Electric Tac Install
Old Feb 19, 2006 | 03:47 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Electric Tac Install
Hey guys:
I could use some electrical info on how to wire an electrical tac in my 87. Thanks in advance
Old Feb 19, 2006 | 02:48 PM
Hooked on Vettes's Avatar
Hooked on Vettes
If you look at the outside of the distributor cap it has a bump out where two push on wire connectors are.
One wire is Red (could be Pink) and is 12 volts.
The other wire is White and is the Tach. signal coming out of the distributor cap.
Splice a wire to the White wire and use that wire for the signal input to you new Tach. Your Digital Dash Tach. should still function properly.
Old Feb 20, 2006 | 12:29 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You can also tap into it where it goes through the firewall.
Old Feb 20, 2006 | 01:13 AM
Demonic85's Avatar
Demonic85
Are you adding a new tach for drag racing?
To Electric Tac Install
