Windshield Wipers Hitting Hood
Old Feb 20, 2006 | 06:48 PM
MR TLS's Avatar
MR TLS
Default Windshield Wipers Hitting Hood
Hi , just got the 95 c-4, all ready i have a small problem, the wipers hit the edge off the hood. i have tryed to adjust the hood up but it still hits. does the 95 have difference wipers? i asked my local dealer and he said no.
Old Feb 20, 2006 | 07:36 PM
kize's Avatar
kize
I believe the left and right wiper arms and blades have different ride heights. Try swapping the blade assemblies. This is how I fixed mine.
Old Feb 20, 2006 | 07:47 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
It is also possible that the springs on the arms are sprung.They hold them against the windsheild.No fixing them they need to be replaced(if that is the problem).
Old Feb 20, 2006 | 07:55 PM
ynk1121's Avatar
ynk1121
I had the same problem when I first got my car. I replaced the blades thinking it was just the wrong size or that brand made them higher but it still happened so I ordered new arms. After comparing the new and old arms I realized the old ones were really bent out of shape causing the problem.
Old Feb 20, 2006 | 07:58 PM
c4cruiser's Avatar
c4cruiser
95-96 wiper arms are a different style from the earlier cars but if the blade assembly was replaced, you'll find that lots of the aftermarket blade assemblies are taller than the factory versions.
There is a Tech Tip on early vs. late C4 wiper arms: https://www.corvetteforum.com/techti...D=42&TopicID=2
Old Feb 20, 2006 | 08:21 PM
aboatguy's Avatar
aboatguy
The last time I replaced my blades they were too tall and hit the hood. So I took the blade assemblies off of the car and removed the rubber part of the blade from the assembly and flattened each arched section a little bit using a precise application of boatguy azz. I reassembled everything and VIOLA blades now park under the hood like they are supposed to. I checked and double checked the PN I bought was supposed to fit a 95/96 Corvette.
Mike
Old Feb 20, 2006 | 08:48 PM
cv67's Avatar
cv67
St. Jude Donor '05
C4cruiser is right. I took the ones off the 89 the other day, and they had plenty of room to spare. They were the type that had the two sections that "moved". The replacements the book called for just barely cleared the hood but they clear. Cross referenced a Bosch brand also, same thing.
Old Feb 20, 2006 | 10:23 PM
aboatguy's Avatar
aboatguy
Bosch blades did not clear on my 95 without a litte flattening.
Old Feb 21, 2006 | 01:04 AM
aminnich's Avatar
aminnich
[QUOTE=MR TLS]Hi , just got the 95 c-4, all ready i have a small problem, the wipers hit the edge off the hood. i have tryed to adjust the hood up but it still hits. does the 95 have difference wipers? i asked my local dealer and he said no.
I got the Bosh blades and found the little hinged lock hit the hood. Took them off and but on ANCO, which do not have the little hinged lock tab on top. The ANCOs just press on and work great.
Old Feb 21, 2006 | 02:22 AM
cv67's Avatar
cv67
St. Jude Donor '05
THAT's the brand I used, ANCO. come close but dont hit.
20 inchers btw.
To Windshield Wipers Hitting Hood
