Nuts?????????
Old Feb 23, 2006 | 01:15 PM
enod's Avatar
enod
Cruising
Default Nuts?????????
Does anyone know where I can get the replacement push nuts that attach the shift boot and the drive selector plate to the bottom of the center console? I have checked all the usual places, Pep Boys, Chevy Dealer, Ecklers, everything on the internet, Home Depot......nothing.
You guys that have replaced your center console before must have located them or attached the boot and shift plate another way. More quality from GM, who the heck thinks up this goofy design?
Any help is appreciated, thanks.................
Old Feb 23, 2006 | 01:37 PM
Chewch87's Avatar
Chewch87
Try a small "hometown" type hardware store like a TrueValue etc. Most have a large assortment of all types of fasteners..nuts, bolts, shims, c nuts etc. They are usually behind a counter or along the wall of the store...displayed in cardboard boxes that pull out...or in plastic bins . Good Luck.
Old Feb 23, 2006 | 01:39 PM
aminnich's Avatar
aminnich
Mine are attached with short, flat head screws. My vette is 95 model, so not sure if you have same mounts.
Old Feb 23, 2006 | 02:06 PM
enod's Avatar
enod
Cruising
Mine is a 1996. On the other end of that flathead screw is what is called a push - nut. The nut slips over the plastic rod of the underneath od the conole, and the metal screw then gets self threaded through the nut.
Old Feb 23, 2006 | 02:12 PM
1quik91's Avatar
1quik91
Try an automotive trim shop or auto upholstery shop, they have a plethora of clips, washers etc. Always wanted to use that word in a sentence. Pletora, plethora, plethora..........
Old Feb 23, 2006 | 02:20 PM
aminnich's Avatar
aminnich
Different design then.
Old Feb 23, 2006 | 04:17 PM
Louis J Hoppmann's Avatar
Louis J Hoppmann
Try Lowe,s they have a good supply of auto type fasteners.
Old Feb 23, 2006 | 08:26 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
My local NAPA has a book with pics of all kinds of wierd clips, fasteners etc. I'll bet you can find what you want there.
To Nuts?????????
