Need Help!
Old Feb 24, 2006 | 02:11 PM
Demonic85's Avatar
Demonic85
Default Need Help!
I know this has been brought up so many times before, but i've never really got an answer to the problem with my headlights. They work just fine, except...
-motor on the driver side wont turn off.
-With switch in off position, pull the switch back a little to turn off motor.
I know there are 3 Relays in the '85, an isolation relay and 2 actuator relays. I've heard it could be the gears need to be replaced. I need to know what part needs to be replaced before I order cause I dont have a lot of money and dont want to waste my time installing parts that dont fix the problem. Will someone please help me???
Old Feb 24, 2006 | 02:49 PM
bogus's Avatar
bogus
uh, that sounds to me like the switch is DOA.... if a trick of the switch shuts the light off, I would bet on the switch.
Old Feb 25, 2006 | 02:44 AM
Demonic85's Avatar
Demonic85
The lights go off, but the motor still runs. Then I pull the **** out about 1/4" and it shuts off the motor.
To Need Help!
