Can anyone tell me the correct way to measure wheel offset. I'm going to swap meets soon looking for wheels for my '92. I know the correct offset is 56mm dont want to buy wheels I cant use. Any input would be great!!
C4 of Year Winner (appearance mods) 2019
Offset is the distance from the wheel centerline to the mounting surface. If the mounting surface is outside the center, the offset is positive. If it's inside, it's negative.
Summary:
Measure distance from wheel inside edge to wheel mounting surface then subtract half of your wheel width.
If they are factory wheels then they will have the size and offset cast into the back of one of the spokes. Don't know if that is the case with the repro wheels.
Summary:
