cutting
Old Feb 25, 2006 | 08:33 PM
takovr's Avatar
takovr
Default cutting
I know I asked this question before but I never really got a answer,
I have a 86 vette and I hurd if you cut the air box lid it will give you more horsepower is this true.?
Old Feb 25, 2006 | 08:35 PM
shacky's Avatar
shacky
Not sere.
Old Feb 25, 2006 | 08:42 PM
one's Avatar
one
Well, not as much of an increase in RWHP as racing stripes.
Old Feb 25, 2006 | 08:52 PM
DarkBlue88's Avatar
DarkBlue88
From: Charlotte NC, behind someone going 10 under the speed limit
Probably not, unless your motor spins faster than a stocker.
Old Feb 25, 2006 | 08:56 PM
PsychoNumber1's Avatar
PsychoNumber1
From: Behind The Redwood Curtain, The State of Jefferson
I hear it allows the air to flow more freely. Much the same way an open exhaust could help hp on most cars, opening up the front end so it breathes better can free up some power too. Look at what turbo chargers and super chargers do. The compress air sent into the engine allowing more fuel to be burned, right? That's my impression at least.
Old Feb 26, 2006 | 09:59 AM
Midnite 88's Avatar
Midnite 88
A cut-lid will "marginally" inprove airflow. I have yet to see a dyno sheet that proves it but, from personal experience, mine seemed slightly quicker 0-60. Also you can hear the air rush when you get on it. With the "louvered" I couldn't hear it.
Old Feb 26, 2006 | 12:41 PM
ED HEISER's Avatar
ED HEISER
Default More Power?
I cut out my lid, removed the frisbee, and changed the exhaust from the cat back to a more open system. I can feel the difference, and I like the sound better. I can't say how much more power it has, but it does take off better. It's not a huge difference, but every little bit makes it more enjoyable. To me it was worth it. Just doing the lid by itself without losing the restrictive mufflers and heavy frisbee won't change much. Your year may not have a frisbee, maybe someone else knows.
On my motorcycle I changed the jets, went to a cut out K&N filter and air box, and changed the exhaust to a 2 into 1 Vance and Hines. The difference in power was amazing, top speed increased 15 mph. So I know that improving the air flow can make a dramatic difference in most vehicles if done correctly, without internal engine modifications.
Of course, if you want real power, you need real money. HP costs money.
To cutting
