shocks needed?
Old Feb 27, 2006 | 12:32 PM
XQIZT's Avatar
XQIZT
Default shocks needed?
Well, I got a 4 wheel alignment hoping that it would rid me of a rather disturbing shaking that I get around 55 mph…it goes away about 70 or so. The alignment and balance did nothing (although the car did need adjustment). I checked the ball joints and they seemed fine. There was no mention of any problems/wear with the steering linkages. All the bushings are there and in decent condition. I’m not sure what else could create this issue, other than worn shocks. Thoughts?
Old Feb 27, 2006 | 01:36 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Interesting post, orlando.
My '96 is going through something similar; a peculiar slight shake above about 70. I've had all four wheels balanced and a four-wheel alignment in an attempt to cure this. Everything checks out, but the vibration is still there.
I'm going to put the stock wheels/tires back on it in several weeks and see if that affects the problem. I'm thinking a tire issue at this point.....
In my case, anyway, it isn't shocks as they are one-year-old Konis. Shocks would have to be pretty bad to allow shake on an other-wise good car.
Good luck and let us know if you find the cause. I'll do the same.
Larry
code5coupe
Old Feb 27, 2006 | 02:03 PM
1stC3Vette's Avatar
1stC3Vette
Have all (4) tires/wheels measured using the Hunter GSP 9700. This machine measures the radial forces in the tire and will do a runout check on the wheel.
Good luck,
Dino
Old Feb 27, 2006 | 02:44 PM
ED HEISER's Avatar
ED HEISER
Default Shocks?
[QUOTE=Orlando85UCFvette]Well, I got a 4 wheel alignment hoping that it would rid me of a rather disturbing shaking that I get around 55 mph…it goes away about 70 or so. The alignment and balance did nothing (although the car did need adjustment). I checked the ball joints and they seemed fine. There was no mention of any problems/wear with the steering linkages. All the bushings are there and in decent condition. I’m not sure what else could create this issue, other than worn shocks. Thoughts?[/QUOTE
Vibration in this speed range is almost always tire related. Even though you had the tires balanced, one or more may still be out of balance, or worse, have a tread separating. Testing by replacement will tell you for sure, but is too expensive unless your tires are close to worn out anyway. If someone was nice enough to switch wheels and tires with you just to test it.......I'm in California......maybe someone near you can help.
Old Feb 27, 2006 | 02:46 PM
ED HEISER's Avatar
ED HEISER
Good luck,
Dino
Dino, what is this machine,do tire places have it?
XQIZT's Avatar
XQIZT
thanks dino....so do all shops have that machine or do i call and ask for it by name? ...another thought, could it be the tie rod end ball joints? i would think that would result in bad performance at all speeds.....bottom line is that i am ready to buy shocks if need be, i think they are the originals (83K). but i don't want to just shot gun the problem now.
Old Feb 27, 2006 | 05:58 PM
89vert's Avatar
89vert
Orlando usually they check ball joints and tie rods before doing an alingment. With that said I'm replacing all the bushings, ball joints and tie rods trying to get rid of a shake like you describe. I know this sounds extreme but the car has 110,000 miles on it and it won't hurt. Also, I will be replacing the tires because they are almost gone and they sit alot. try this link. It will help you locate a shop with the Hunter GSP 9700 near you. Hope this helps. Tim
http://www.gsp9700.com/pub/search/findgsp9700.cfm
Old Feb 27, 2006 | 06:01 PM
89vert's Avatar
89vert
Ed, go to this site and it describes what the machine measures when balancing a tire. Tim
http://www.gsp9700.com/pub/features/how.cfm
Old Feb 27, 2006 | 06:18 PM
SK.LT1's Avatar
SK.LT1
Shocks will not cause this problem.If it`s not the tires perhaps one or more of your U-joints or possibly wheel bearings is starting to go bad.
Old Feb 27, 2006 | 07:57 PM
sonny1974's Avatar
sonny1974
I had the same problem shake around 50 and then smoth out at 70 had the front tires balanced still shook. found it was a lift front tire change it problem solved. hope this helps. sonny95lt1
Old Feb 27, 2006 | 10:25 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Default May sound stupid...
Try looking at the back side of your rear wheels. If you have grease or dirt stuck to them that could be your problem.
Old Feb 28, 2006 | 09:37 AM
XQIZT's Avatar
XQIZT
89vert…thanks for the link…I’ll be calling this afternoon…eventually, I will be replacing all the bushings/ball joints/shocks anyway but I don’t have the $1000 or so to do it all right now. the tires were wearing hard on the outside (camber was off) now that its fixed, I am hoping that this new balance will find my problem. Although if it can’t be balanced in the traditional way, is the only option to buy new tires? I hope not.
As far as wheel bearings and u-joints, they’ve been replaced in the rear, so I hope they haven’t gone bad yet.
Old Feb 28, 2006 | 10:14 AM
1stC3Vette's Avatar
1stC3Vette
Sorry for not getting back to you guys sooner. I just finally got back on the web. Thanks to 89vert for providing the link. This machine works well. It looks like a tire balancer, but uses a wheel to measure the radial forces of the tire and can pinpoint a potential problem.
Good luck,
Dino
To shocks needed?
