Painting inside?
Old Feb 27, 2006 | 11:44 PM
Red Dragon 79's Avatar
Red Dragon 79
Default Painting inside?
for some reason when i bought my 94 the console plastics(the section with the gear shift and cup holders, and the radio and vent housing) they were pealing and had some paint substance missing, and the reaveled is fading a little to a blueish color. anyway, i am looking to repaint the plastic pieces, what would be a good paint to use? i need something good for plastics, something that won't scratch easy, and something for heat. i want to paint it a dull black color. any suggestions?
Old Feb 28, 2006 | 12:10 AM
Red Dragon 79
i have been reading that kylon fusion might have something?
Old Feb 28, 2006 | 12:14 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Mine was like that they all do have dulso peeling after time.I bought a brushed aluminum kit to cover it(look at my pics) and it looks great.I got mine from eBay for ~$100.
Old Feb 28, 2006 | 12:17 AM
Red Dragon 79
i have been thinking for a while about doing the brushed aluminum, i want to try the paint route.
your car looks great by the way!
Old Feb 28, 2006 | 12:40 AM
MaSTeRofDZaSTeR's Avatar
MaSTeRofDZaSTeR
From: "Drive like Hell, you'll get there faster." Tucson AZ
I was just gonna mention the Krylon Fusion in Black of course. I have some, but never used it on interior(I was thinking about using it for rear Tail Louvers cuz it binds so well supposedly to plastics). I Also have the same interior problem on my '90. Not too noticeably bad, but some areas I definitely wanted to paint black around the console. Even maybe some or mostly all the grays. You can be my guinea pig. LOL j/k. Seriously though lemme know how it turns out if you do go that route w/pics if possible. I'm considering the same, but wanna see it first.
Old Feb 28, 2006 | 12:48 AM
Red Dragon 79
deal, tomorrow i'll find some krylon fusion and be the guinea pig! i might as well try it, i have been reading about it for the last two hours. sounds like the paint to use. i'll keep you updated.
Old Feb 28, 2006 | 02:19 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
NAPA carries the rubber spray coating that goes on the plastic pieces.
I forget the name of it but if you pm me, I can look at the can tomorrow.
The rubber coating is made by NAPA Plasti it's s spray on rubber, comes in different colors.
Old Feb 28, 2006 | 09:42 AM
RFDrpm's Avatar
RFDrpm
Im in the process of using Krylon right now.
Get the Ultra Satin Finish.
Satin finsh is still too glossy.
Then finish up with the Clear.
Remember to do a fine sand between coats. That way the stuff that would peal comes off and you can see your problem areas before you put it back together.
Pm me for more details.
Old Feb 28, 2006 | 07:06 PM
Red Dragon 79
thanks, that helps out. is 2000 grit good enough?
Old Feb 28, 2006 | 09:33 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
you could always paint the back side first before you go in head first with the top
Old Feb 28, 2006 | 10:05 PM
RFDrpm's Avatar
RFDrpm
2000 should be for your final sand before clear coat, and after clear.
For your inital sand and in between coats use some thing like 500 or 1000.
Just put a another 4 coats on tonight after a good sanding. WOW it is really starting to look good. I think one more coat and a color sand, and we are on to clear.
Old Feb 28, 2006 | 10:56 PM
Zix's Avatar
Zix
I had this done when i repainted the car a couple years ago...
Old Feb 28, 2006 | 11:01 PM
js292's Avatar
js292
I just did mine this week, I used a SEM product code ? I'll post the number tomorrow. But I purchased some replacement parts and they match the parts I panted perfectly.
Old Feb 28, 2006 | 11:12 PM
Red Dragon 79
zix, what type of paint did you use on that interior, it looks great!! i think i have commented on it before!!
Old Feb 28, 2006 | 11:15 PM
Red Dragon 79
i am in the middle of sanding everything down, i wish there were more hours in the day. as far as the paint that is on it goes, could i use a weak paint thinner to get some of this paint off? sanding it seems to be the wrong approach, although i know that thinner and plastic DON'T mix well, if i rub the paint off and then wash the thinner off directly after would the plastic stay strong?
Old Feb 28, 2006 | 11:27 PM
Zix's Avatar
Zix
That is actually House of Color paint...it's the same silver I had sprayed on the outside of the car. I stripped off the rubber coating using fine grit sand paper and and some pretty weak paint thinner...the painter then sprayed them. They came out pretty good and they've held up very well so far!
Old Feb 28, 2006 | 11:28 PM
Red Dragon 79
thanks for the info, looks like i am headed in that direction then. do you get a lot of scratching on the painted parts?
Old Feb 28, 2006 | 11:36 PM
Zix's Avatar
Zix
A little, but not much at all really, and certainly nothing that couldn't be easily touched up. The only ones I have are on the console right above the cup holders from when I used to prop my scanner up there to watch it as I drove the car to check out my fuel trims and timing
To Painting inside?
