C4 Floor Problems
Old Feb 28, 2006 | 06:18 PM
AILERON's Avatar
AILERON
Default C4 Floor Problems
I have big floor cracks and holes.
Has anybody done their own repairs, and if so, would you do it again?
Has anybody had a shop do it, and if so, would you let them do it again?
Thanks...
Old Feb 28, 2006 | 07:16 PM
mpcorvette's Avatar
mpcorvette
I have done it a few times now. Just about every time I take it to a shop and they put it on the lift incorrectly . Anyway, all I do is go get some fiberglass resin and a sheet of fiberglass fabric and presto. I give it a good sanding and re-spray it with some black paint and its done. Too easy, and the resin gives you a great contact high . Just kidding, dont tell my boss...
Old Feb 28, 2006 | 10:13 PM
WEH 2000C5's Avatar
WEH 2000C5
I basically did it the way MPCORVETTE suggests. My car apparently had small road damage to the rt footwell.The patch kit worked good. I had to remove the carpeting on the inside & the metal guard piece on the exterior .
No I would not take it to a body shop to repair it. It is a very basic home repair.
Old Mar 1, 2006 | 01:55 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I get the resin from ACE Hardware ,fiberglass and the color to match the resin,you just mix the color prior to puttting the drops of catilas in the resen.I use a paint brush and coat the floor pan and install the fiberglass and once it is streight ,Pour the resin as deep as you need it to be.
I also use duck tape to block the holes if you need to .
Old Mar 1, 2006 | 02:01 AM
AILERON's Avatar
AILERON
Thanks, guys. I'll tackle it this weekend.
Old Mar 1, 2006 | 11:06 AM
redwing76's Avatar
redwing76
www.evercoat.com
To C4 Floor Problems
